RPLIDAR A3 - 360 Degree LiDAR Laser Range Scanner (25m)
$599.00
SKU: DFR0583
A 360-degree laser scanner with a 25m range radius, sampling 16000 times per second, suitable for indoor and outdoor use, with low noise and long lifespan.
Purchase this product and earn 4490 reward points, which are tied to VIP membership program. Learn More >
RPLIDAR A3 - 360 Degree Laser Scanner(25m,16000 samples per second)
Ranging 16000 Times per Second
The sample rate of LIDAR directly decides whether the robot can build map quickly and accurately. RPLIDAR A3 improves the internal optical design and algorithm system to make the sample rate up to 16000 times, which is much better than most competitors.
RPLIDAR A3 - 360 Degree Laser Scanner Comparison under different working conditions
25 Meters Range Radius
With algorithm optimization, the ranging radius of RPLIDAR A3 has been increased to 25 meters, which means more environment outline information is to be collected
RPLIDAR A3 - 360 Degree Laser Scanner Range Radius:25M
Indoor and Outdoor Availability
PLIDRA A3 supports to work under two modes alternatively: enhanced mode and outdoor mode . In enhanced mode, RPLIDAR A3 works with the maximum ranging radius and sampling rate to realize an optimistic mapping performance in indoor environments.
While in outdoor mode, RPLIDAR A3 works with a more reliable resistance to daylight interference. It keeps its stable performance when detecting white and black objects.
RPLIDAR A3 - 360 Degree Laser Scanner Indoor and Outdoor Availability
360 Degree Omnidirectional Laser Range Scanning
The ranging core of RPLIDAR A3 runs clockwise to perform a 360 degree omnidirectional laser range scanning for its surrounding environment and then generate an outline map for the environment.
RPLIDAR A3 360 Degree Omnidirectional Laser Range Scanning
RPLIDAR A3 - 360 Degree Laser Scanner 4-cm thick size
Brushless Motor, Low Noise, New Non-contact Drive
Compared with the traditional belt drive mode, RPLIDAR A3 uses the self-designed brushless motor to reduce the mechanical friction in running. Therefore, the RPLIDAR A3 can run smoothly without any noise.
RPLIDAR A3 - 360 Degree Laser Brushless Motor, Low Noise
RPLIDAR A3 adopts laser triangulation ranging principle, and with high-speed RPVision ranging engine, it measures distance data 16000 times per second and keep its excellent performance in a long distance.
RPLIDAR A3 - 360 Degree Laser Scanner with RP Vision 3.0
OPTMAG Original Design, 5 Years Ultra-long Life
Most traditional non-solid LIDARs use slip ring to transfer power and data information, however, they only have thousands of hours of life due to mechanical wearing out. SLAMTEC has integrated the wireless power and optical communication technology to self-design the OPTMAG technology, which breakouts the life limitation of the traditional LIDAR system. It fixes the electrical connection failure caused by the physical wearing out so as to prolong the life to 5 years and even more.
RPLIDAR A3 - 360 Degree Laser Scanner with OPTMAG Original Design
Laser Safety Standard Class 1
The RPLIDAR A3 system adopts the low power infrared laser light as its light source, and drives it by using modulated pulse. The laser emits light in a very short time frame which can ensure its safety to human and pets. It has already reached Class 1 Safety Standard.
RPLIDAR A3 - 360 Degree Laser Scanner Safety Standard: Class 1
  • Model: RPLIDAR A3
  • Ranging range: 0.2 - 25 meters
  • Scanning angle: 0~360 degrees
  • Ranging resolution: ≤1% of the actual distance (ranging ≤12m)
                       ≤2% of the actual distance (ranging 12m~25m)
  • Angular resolution: 0.225°
  • Scanning frequency: typical value: 15Hz (10Hz-20Hz adjustable)
  • RPLIDAR A3 - 360 Degree Laser Range Scanner x1
Mechanical LiDAR (Laser Radar) Selection Guide
Blog Mechanical LiDAR (Laser Radar) Selection Guide
Mar 13, 2020
Discover the Power of LiDAR Technology: A Comprehensive Guide
Blog Discover the Power of LiDAR Technology: A Comprehensive Guide
Feb 26, 2020
Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
Blog Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
Sep 13, 2023
Only 1 Left
