SLAMTEC Mapper M2M2 - 360° Laser Mapping Sensor (40m)
$559.00 $699.00
SKU: DFR0628
error
Purchase this product and earn 5590 reward points, which are tied to VIP membership program. Learn More >
SLAMTEC MAPPER M1M1-360°Laser Mapping Sensor TOF 20m
Slamtec Mapper, a new laser range scanner category integrating map building and real-time localization and navigation, contains the SLAMTEC third-generation high-performance SLAM engine and laser range scanner. Plug and play, without any external dependence. It is suitable to be applied in application fields like robot localization and navigation, environment surveying and mapping and etc. SLAMTEC MAPPER M1M1-360°Laser Mapping Sensor's small size
Large Scenarios and High-quality Mapping
Slamtec Mapper adopts SLAMTEC third-generation high-performance SLAM graph optimization engine and SharpEdge™ mapping technology to realize a high accurate thousand-square-meter map building and real-time localization, and it can actively detect the closed-loop and correct map. The mapper is an ideal choice for users to realize mapping and re-localization in various complicated scenarios and output map and localization data that meets users' expectations.
SLAMTEC MAPPER M1M1-360°Laser Mapping Sensor Large Scenarios and High-quality Mapping
Slamtec Mapper just needs a USB power cable to work well, without any additional support or accessories.
SLAMTEC MAPPER M1M1 Laser Mapping Sensor is Plug and play
Tilting Compensation and Fast Moving
With built-in inertial navigation system with nine degrees of freedom, Slamtec Mapper can work properly in tilting and shaky hand-held mode and ensure excellent map data quality. In addition, it supports moving fast with a maximum speed of 2m/s.
SLAMTEC MAPPER M1M1 Laser Mapping Sensor Tilting Compensation and Fast Moving
Indoor and Outdoor Availability
Whether in complicated indoor environment or outdoor environment with direct daylight, Slamtec Mapper shows a good performance in mapping and localization in those complicated scenarios.
SLAMTEC MAPPER M1M1 Laser Mapping Sensor Indoor and Outdoor Availability
Fully Compatible with ROS, Easy Data Analysis
Slamtec Mapper provides completed cross-platform SDK and tools both on the phone and PC side for users to evaluate, develop and use. Through matched ROS driver, you can integrate the generated map and localization data into the ROS environment seamlessly.
SLAMTEC MAPPER M1M1 Laser Mapping Sensor is Compatible with ROS
More Than A Mapper
Slamtec Mapper is not only a mapper for mapping and localization, you can also use it directly as a laser range scanner. Via SDK or ROS node, you can easily put the data of the laser range scanner into the user's current system.
SLAMTEC MAPPER M1M1 Laser Mapping Sensor is Not Only A Mapper
Built-in WIFI, Ethernet port, Easy communication
With built-in access point and station mode WiFi as well as 100M Ethernet port, you can get the real-time map and localization data generated by Slamtec Mapper through the designed mobile application.
SLAMTEC MAPPER M1M1 Laser Mapping Sensor Built-in WIFI, Ethernet port
SLAMTEC MAPPER M1M1 Laser Mapping Sensor's High Performance
  • Commercial robot
  • Outdoor robot
  • Environment surveying
  • Handheld mapping
  • Model: M2M2
  • Measuring Range: 0.1m - 40m
  • Sampling Frequency: 9.2K
  • Rotational Speed: 8Hz-15Hz
  • Angular Resolution: 0.391°
  • Motor: Brushless
  • Dimensions: 77.1 x 57 x 74.9mm
  • Weight: 165g
  • System Voltage: 5V
  • System Current: 750mA - 1300mA
  • Power Consumption: 3.75W-6.5W
  • Output Ethernet: (802.3/802.3u ) WiFi(802.11a/b/g/n/ac )
  • Temperature Range: -5℃-45℃
  • Angular Range: 360°
  • Range Resolution: 3cm
  • Accuracy: ≤5cm
  • Maximum Moving Speed: 2m/s
  • Frequency Of Data Refresh: 10Hz
  • Maximum Area: 300m x 300m
  • Mapping resolution: 0.05m
  • Accuracy: < 0.02m
  • Graph Optimizing Working Time: About 1 hr
  • Maximum Inclination Angle: ±3°
    • SLAMTEC MAPPER M2M2-360°Laser Mapping Sensor x1
    Mechanical LiDAR (Laser Radar) Selection Guide
    Blog Mechanical LiDAR (Laser Radar) Selection Guide
    Mar 13, 2020
    Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
    Blog Exploring the Differences: Solid-State LiDAR vs Mechanical LiDAR
    Sep 13, 2023
    Dantes. Nov 19, 2021
    Where do I begin... if you can read this review, buy it. Plug & Play, was up and running in no time. Slamtec SDK for Win requires some creativity and patience Very pleased with mapping resolutions. A lot of good R&D to be had with this module. Use good quality network cable.
    Out Of Stock
