TF-Luna is a single-point ranging solid state Lidar, based on ToF principle. With unique optical and electrical design, it can achieve stable, accurate and highly sensitive range measurement.
Small Size Design
High Performance & Economical
This is a close-range, low-cost ToF single-point solid-state lidar with a range of 0.2m–8m. This solid-state lidar has high stability, high sensitivity, and high precision.
Detection distance
TF-Luna solid-state lidar's detection distance is up to 8m, the blind zone is 0.2m, and distance resolution is 1cm.
Minimum edge length of 3.5 cm within a detection distance of 1m;
Minimum edge length of 28 cm within a detection distance of 8m;
Easy to get start, high level of generality
The power supply voltage of TF-Luna lidar distance sensor is 5V, equipped with UART communication interface, the communication level is 3.3V. TF-Luna is compatible with Arduino, Raspberry Pi and other platforms.
Wiring Diagram of TF-Luna Solid State LiDAR and Arduino Uno
Wide Application Scenarios
TF-Luna is an economical solid-state lidar that is low-cost and can be widely applied to many development scenarios.
Sep 08, 2025
A great small lightweight module. One feature that seems to be undocumented is that pulling pin 5 (shown as unconnected in the manual) to ground selects I2C mode without any software or firmware needed.
May 17, 2025
This is very fast, much accurate and easy to use.
Apr 06, 2023
This can be very close to its rated indoor range outdoors. With a firmware update, you can even get it to work on I2C.
