MindPlus Arduino Coding Kit with 25 Tutorials & 18 Sensors – Ideal for Kids Learning Programming
$99.00
SKU: KIT0152-EN
The kit is a coding tool for kids featuring Arduino Uno R3, sensor board, and 18 sensors. It supports graphical programming and language conversion for learning.
Purchase this product and earn 490 reward points, which are tied to VIP membership program. Learn More >
The MindPlus Coding Kit for Arduino is an ideal educational tool for kids to start their coding journey. Featuring an Arduino Uno R3 mainboard, sensor expansion board V7, and 18 essential sensors and actuators, this kit enables kids to bring their creative ideas to life. The Gravity interfaces on the sensors simplify the connection process, while support for Mind+ and Arduino IDE programming caters to varying levels of coding experience. Mind+ offers a visual programming environment akin to Scratch, making it accessible for beginners and providing a clear pathway to understanding coding concepts.
What Is Mind+?
Mind+ is a graphical programming platform compatible with mainstream boards and open-source hardware. It supports AI and IoT projects, allowing users to build programs by dragging coding blocks or using advanced languages like Python and C++. This tool helps users explore the joys of creation with ease.
Download Mind+ at http://mindplus.cc/en.html
01. Offline Programming Editor
Mind+ is a programming tool, which allows you to build a program by dragging and snapping coding blocks. With tons of tutorials, sample projects and a large community, it is one of the best tools for you to learn programing from absolutely zero!
02. Create Interactive Projects with Hardware
Mind+ supports a wide range of hardware including Arduino, micro:bit or even a series of ESP32-based educational microcontrollers, which makes it possible to let the program change your real life. Not only that you can use microcontrollers to interact with PC in real time, but also you can upload the code and let them work as standalone smart devices.
03. Wide Range Add-on Component Support
The build-in component list allows you to one-click add electronic modules to your project. You may choose from sensors, actuators, display or communication modules to make your project fun and powerful.
04. Convert Blocks Into Coding Languages
The build-in interpreter in Mind+ converts blocks into Python or C language, creating a steady but progressive learning path for learning how to code.
Welcome to Mind+ Column, more ways to play!
Tutorial
This kit includes 25 engaging projects, ranging from basic LED lighting to advanced IoT and smart home applications. It covers algorithms, computing systems, networking, and data analysis, enhancing coding skills and logical thinking.
Content
Field Distribution Chart
Course Structure
The course structure clearly describes how a lesson is implemented, which can help to build up projects conveniently.
Tutorial Case
  • Graphical Programming: Build programs using drag-and-drop blocks or transition to Python and C++.
  • Interactive Projects: Compatible with Arduino, micro:bit , and ESP32 microcontrollers for real-time interaction and standalone functionality.
  • Extensive Component Support: Easily integrate sensors, actuators, displays, and communication modules.
  • Progressive Learning Path: Convert blocks into code to gradually learn programming languages.
  • Controller: DFRduino UNO R3
  • Power Supply: 6 AA batteries or 6~12 power adaptor
  • Weight: 0.63kg
    UNIHIKER K10: AI Smart Store
    Projects UNIHIKER K10: AI Smart Store
    Yakroo108
    Jun 29, 2025
    Training AI to Learn Chinese
    Tutorial Training AI to Learn Chinese
    Lucas Fernando
    Jul 07, 2025
    DFRobot Wish You a Merry Christmas
    Blog DFRobot Wish You a Merry Christmas
    Dec 22, 2021
    MindPlus Coding Kit for Arduino Started Tutorial
    Course MindPlus Coding Kit for Arduino Started Tutorial
    Nov 27, 2024
