RPLiDAR S2 - ToF LiDAR 360° Laser Range Scanner (30m, 5V, UART, IP65)
$299.00 $399.00
SKU: DFR1022
The laser range scanner offers 360° scanning, 30m range, 32KHz sampling, IP65 protection, strong light resistance, and seamless integration for robotic use.
Purchase this product and earn 2990 reward points, which are tied to VIP membership program. Learn More >
RPLiDAR S2 360° Laser Range Scanner's High Performance
DTOF Ranging Method
Thanks to the DTOF (Direct Time-of-Flight) technology developed by SLAMTEC, RPLIDAR S2 guarantees consistent ranging resolution. Even in longer distance, the resolution always keeps the same. Also, DTOF allows RPLIDAR S2 to detect almost ANY thing with different material types, no matter a darker object, a high reflective mirror, or even transparent glass.
RPLiDAR S2 360° Laser Range Scanner DTOF Ranging Method
30 Meters Range Radius
The ranging distance radius of RPLIDAR S2 is up to 30 meters, which meets the high demand requirements of robotic navigation applications in commercial scenarios, such as hotels, restaurants, shopping malls, office buildings, etc.
RPLiDAR S2 360° Laser Range Scanner 30 Meters Range Radius
32000 Times per Second sample rate
RPLIDAR S2 improves the internal optical design and measurements system to achieve the sample rate up to 32000 times, which makes more environmental details to be retrieved during the mapping and navigation process.
RPLiDAR S2 360° Laser Range Scanner 32000 Times per Second sample rate
Resistance to Strong Sunlight, Workable in both Indoor and Outdoor
RPLIDAR S2 has a stable ranging and high-resolution mapping performance in the indoor and outdoor environment, even in 80Klux strong sunlight interference.
RPLiDAR S2 360° Laser Range Scanner Resistance to Strong Sunlight, Workable in both Indoor and Outdoor
Excellent ranging accuracy
For objects with different reflectivities, such as lenses and mirrors with high reverse surfaces, consistent and accurate distance measurements can be obtained.
RPLiDAR S2 360° Laser Range Scanner Excellent ranging accuracy
Small & Compact size, fits the overall appearance requirements of robots
The height of the scanning optical area of RPLIDAR S2 is only 18mm, which makes it easy to be embedded.
RPLiDAR S2 360° Laser Range Scanner Small & Compact size, fits the overall appearance requirements of robots
High compatibility
RPLIDAR S2 shares the same interface port with A series RPLIDARs. Existing products can upgrade to RPLIDAR S2 seamlessly without the need of changing hardware or software design.
RPLiDAR S2 360° Laser Range Scanner High compatibility
Support serial ports and network ports communication modes
The S2 provides serial ports and network ports communication modes. It is convenient for users to use in various environments.
RPLiDAR S2 360° Laser Range Scanner Support serial ports and network ports communication modes
IP65 proof level
IP65 proof level, combined with a cover to protect its interior mechanism from external interference, provides a stable working environment and meets the industrial application.
RPLiDAR S2 360° Laser Range Scanner IP65 proof level
RPLiDAR S2 360° Laser Range Scanner Safty Standard:Class 1
RPLiDAR S2 360° Laser Range Scanner's Application 01
RPLiDAR S2 360° Laser Range Scanner's Application 02
RPLiDAR S2 360° Laser Range Scanner's Dimension
Dimension
RPLiDAR S2 360° Laser Range Scanner's Selection Guide
Selection Guide
  • 32000 times/second sampling speed
  • 30m measuring radius
  • 80000lux strong light anti-interference
  • IP65 proof level
  • IEC-60825 Class 1 laser safety standard
  • CE, FCC, FDA, IEC, REACH, ROHS compliant
  • Robot navigation and obstavle avoidance
  • Obstacle detecting and avoiding of AGV
  • Parking lot monitoring
  • Environment perception and autonomous movement of low-speed unmanned vehicles
  • Multi-point touching and man-machine interaction
  • Power Supply: 5V
  • Operating Current: 40mA(5V power supply, in sleep); 400mA(5V power supply, working)
  • Measuring Radius: 0.05-30m for white objects; 0.05-10m for black objects
  • Sampling Frequency: 32KHz
  • Scanning Frequency: 10Hz
  • Angular Resolution: 0.12°
  • Ranging Accuracy: ±30mm
  • Ranging Resolution: 13mm
  • Protection Class: IP65
  • Anti-ambient Light: >80000Lux
  • Scanning Range: 360°
  • Interface: TTL UART
  • Communication Rate: 1Mbps
  • Size: 77*77*38.5mm/3.03*3.03*1.52”
  • Weight: 190g
  • Operating Temperature Range: -10°C-50°C
  • Power Supply: 5V
  • Weight: 190g
  • RPLIDAR S2 x1
  • USB Adapter x1
  • Mirco-USB Cable x1
  • Power Cable x1
  • Instruction Card x1
  • FAQ
    Jorge.Hernández Dec 20, 2025
    Excelent shopping service, excellent and fast delivery up to America. The RPLiDAR excedded my expectations and requirements.
