Gravity: Offline Voice Recognition Module (121 Built-in Commands, 17 Custom Commands, I2C/UART)
$16.90
SKU: SEN0539-EN
  • $16.50 3+ items
  • $16.00 5+ items
  • $15.50 10+ items
Offline Command Recognition, Not Speech-to-Text. The module offers offline speech recognition with 121 pre-programmed commands, supports 17 custom commands, and is compatible with Arduino, micro:bit, and ESP32.
Purchase this product and earn 169 reward points, which are tied to VIP membership program. Learn More >
The Offline Speech Recognition Module is an efficient solution ideal for human-computer interaction, machine learning, voice assistants, and smart home voice control projects. It is easy to use and compatible with Arduino, micro:bit, and ESP32, with detailed tutorials provided. It offers plug-and-play functionality through I2C and UART. The module supports recognition of 121 built-in English command words, with additional customizable commands. (e.g., recording a cat's meow for an automatic feeder). This module is designed for command recognition (keyword-based), not full speech-to-text or AI conversation. It is highly integrated, including an onboard speaker and microphone, providing real-time voice feedback.
Easy to Use
The offline voice module is simple and compatible with existing platforms like Arduino UNO, micro:bit, and ESP32, with detailed Arduino IDE tutorials and Makecode tutorials. It supports plug-and-play through I2C and UART communication methods, allowing easy integration into projects.
Compatible with Arduino, micro:bit, Raspberry Pi, ESP32
121 Ready-to-Use Words
The built-in commands are commonly used in educational and smart home scenarios, allowing for immediate use without any configuration, such as "Play music," "Open the door," "Turn on the light," and "Close the window." Here is the full list of command words.
Offline Speech Recognition Module Built-in 121 command words
Self-Learning Function
The self-learning function is user-friendly, allowing users to add 17 customized command words. Any language or sound can be trained as a command, providing great flexibility for interactive audio projects.
Teaching the device new commands is simple. Activate the learning mode with the wake-up word, then say "Learning command word," and repeat the desired command three times. After these steps, the device will have learned the new command. Detailed instructions are provided to ensure an easy learning process.
Offline Speech Recognition Module Self-Learning Function
No Internet Connection, More Secure
Users need not worry about their conversations being recorded and uploaded to the cloud. The module functions seamlessly in outdoor projects, schools, and other environments with unstable networks. Unlike existing online voice assistants that rely on cloud platforms and require internet access, potentially compromising device data privacy during use.
High Integration, Saving More Space
The offline voice module integrates an onboard speaker and microphone. High integration saves space and eliminates the hassle of complicated wiring, enhancing the project's neatness and stability.
Offline Speech Recognition Module High Integration, Saving More Space
Real-Time Voice Feedback
Users can immediately receive recognition results during use, improving user experience and convenience.
The Offline Speech Recognition Module is an easy-to-use, highly integrated solution perfect for various projects, offering 121 built-in commands, 17 customized commands, real-time voice feedback, and secure offline operation without the need for an internet connection.
offline voice recognition module features
Version History & Important Information
V1.1 (May 8, 2025):
This version includes minor iterative refinements focused on physical handling and assembly convenience:
  • Improved Speaker Connection: The onboard speaker connection is an easier plug-and-play connector (V1.0 has a soldered connection). This simplifies assembly and modification.
  • Enhanced Sensor Mounting: Mounting holes have been added to the sensor board for more secure attachment.
  • V1.0 (March 2023):
    The original robust and fully capable module. It provides the complete suite of offline speech recognition features and offers a highly effective and reliable user experience.
    Version Update of Gravity: Offline Language Learning Voice Recognition Sensor
  • User-Friendly: Plug and play, compatible with Arduino UNO, micro:bit, and ESP32.
  • 121 Pre-Programmed Commands: Ready for immediate use without any setup.
  • Self-Learning Capability: Supports the addition of 17 customized command words.
  • Offline Operation, Enhanced Privacy: No network required.
  • High Integration: Includes an onboard speaker and microphone.
  • Instant Voice Feedback: Provides real-time recognition results.
  • Voice recognition interaction
  • Voice-controlled terminal
  • Competition and project development
  • Operating Voltage: 3.3 - 5V
  • Maximum Operating Current: ≤370 mA (5V)
  • Communication: I2C/UART
  • I2C Address: 0x64
  • Fixed Commands: 121
  • Fixed Wake-up Command: 1
  • Custom Commands: 17
  • Learning Activation Command: 1
  • Onboard Microphone Sensitivity: -28dB
  • Module Size: 49×32 mm / 1.93×1.26”
  • Operating Temperature: 0-70℃
  • Gravity: Voice Recognition Module - I2C & UART (V1.1) x1
    DIY Voice-controlled Window Blinds System
    Media DIY Voice-controlled Window Blinds System
    DIY Builder
    Feb 13, 2025
    Voice Controlled Digital Cute Pikachu
    Projects Voice Controlled Digital Cute Pikachu
    Muhammad Ahsan Fillah Abadi, Evan cahya Putra, Riezky Ramadhan
    Sep 05, 2023
    DFRobot Offline Voice Recognition Sensor - Learning Mode
    Media DFRobot Offline Voice Recognition Sensor - Learning Mode
    Mahesh Yadav
    Sep 16, 2023
    DFRobot Offline Voice Recognition Sensor - Demo
    Media DFRobot Offline Voice Recognition Sensor - Demo
    Mahesh Yadav
    Sep 16, 2023
    Smart Waiter - Intelligent Voice Assistant in Restaurant
    Projects Smart Waiter - Intelligent Voice Assistant in Restaurant
    Hackster.io
    Sep 16, 2023
    Getting started with DFRobot Voice Recognition Sensor
    Projects Getting started with DFRobot Voice Recognition Sensor
    Mahesh Yadav
    Sep 16, 2023
    KOUBELAN RICHARD.AKPAGNI Nov 08, 2025
    Outstanding voice recognition module! The Gravity: Offline Language Learning Voice Recognition Sensor is very responsive and works perfectly without any internet connection. I tested it with an ESP32 and Arduino — setup was straightforward using I²C, and the UART interface works just as well. It recognizes commands quickly, even in slightly noisy environments, and the custom training feature is a big plus. This module is ideal for offline IoT devices, smart robots, or home automation projects where privacy and low latency are essential. Great performance, clear documentation, and typical DFRobot quality — highly recommended!
    Harry Herman Jun 27, 2024
    DFRobot has a robust wiki that goes in great detail for their products, including this module. The GitHub contains the Arduino library and an example so you can deploy this in minutes.
    Included JST connector is nice as having to buy them when not included can be irritating.
    Got up and running with an ESP32 I had lying around in less than 5 minutes and had serial output immediately. (SDA corresponds to GPIO21, SCL corresponds to GPIO22 in case you're planning on using an ESP)
    I plan on integrating this into some projects I plan to give as gifts, eliminating the ridiculousness of having to pair everything with WiFi and have an internet connection. I'm also debating integrating it into my ESPHome setup.
    Recognition works well and range is better than expected (expect many meters of range in a clear sound environment). Occasional false/failed recognitions in noise saturated environments, but that's to be expected.
    Onboard learning behaves exactly as described on wiki and is self contained to the module. Simple and doesn't require programming at all.
    DFRobot has a lot of resources available to tinkerers and plenty of community projects to inspire you on your next project if you ever get lost or confused.
    Alan. Jul 14, 2026
    Great voice recognition - works awesome.
