New: seeMote Cube for visionOS Developers - Build physical input for Apple Vision Pro apps. Learn More ›
RS485 Soil Temperature, Moisture, EC Sensor for Climate Control in Greenhouses (IP68, 5-30V, Arduino Compatible)
$39.00
SKU: SEN0601
  • $38.00 3+ items
  • $37.00 5+ items
  • $36.00 10+ items
A durable soil sensor for real-time monitoring of temperature, moisture, and conductivity, compatible with Arduino, suitable for smart farms and greenhouses.
Purchase this product and earn 390 reward points, which are tied to VIP membership program. Learn More >
The RS485 Soil Sensor is a highly accurate and durable solution designed for real-time monitoring of soil temperature, moisture, and electrical conductivity (EC). The soil detector operates within a 5-30V wide voltage range and communicates data via the MODBUS-RTU protocol using RS485, ensuring reliable data transmission for integration with automated irrigation and climate control systems. It can be paired with an Arduino UNO and a TTL to RS485 expansion board for easy setup. The soil measure sensor is perfect for smart farms growing rice, corn, and soybeans, as well as greenhouse environments requiring high precision in climate irrigation management.
The protection level of the soil sensor is IP68, and it is vacuum-filled and sealed with black flame-retardant epoxy resin. The probe material is made of 316 stainless steel, which is rust-proof, waterproof, anti-corrosion, salt-alkali corrosion resistance, and long-term electrolysis resistance. It is more affected by the soil salt content. It is small, can be buried in the soil for a long time, and is suitable for various soil types.
The soil sensor has an automatic temperature compensation function for conductivity, which ensures measurement accuracy no matter how the environment changes.
It is widely used in agricultural irrigation, greenhouses, flowers and vegetables, grassland and pastures, soil rapid testing, plant culture, scientific experiments, grain storage and the measurement of moisture content and temperature of various particulate matter.
Soil temperature has a direct impact on plant growth. Proper soil temperatures help promote plant root growth and the ability to absorb nutrients. Generally speaking, higher soil temperature is helpful for plant growth because it can increase plant metabolism, promote nutrient absorption and transport, and increase plant microbial synthesis capabilities, thereby promoting plant growth rate and yield.
In addition, appropriate soil moisture helps plant roots absorb water and nutrients and maintains water balance within plant cells. If the soil moisture is too low, plant roots will be limited in absorbing water, which can lead to plant dehydration, stagnant growth or even death. Excessive soil moisture may cause hypoxia in plant roots, hinder normal respiration and nutrient absorption of roots, and thus affect plant growth and development.
Soil electrical conductivity (EC) is the level of salt in the soil (salinity). These parameters are important indicators of soil fertility and health, and ultimately affect plants. When soil has high salt content, the salt makes it difficult for plants to absorb water, even if the moisture content in the soil is high. This condition will eventually "burn" the plant. Plants grow best in their preferred environment within the optimal range of soil moisture, temperature and EC levels. Growers need data on these parameters and understand what actions need to be taken to ensure plant health and higher yields.
  • Wide Voltage Range: Supports 5-30V power supply.
  • RS485 Output: Compatible with Arduino and other systems.
  • Automatic Temperature Compensation: Ensures measurement accuracy regardless of environmental changes.
  • Stainless Steel Probe: Designed for long-term burial in soil or water.
  • IP68 Protection Level: Vacuum-filled and sealed with flame-retardant epoxy resin.
    Applications of RS485 Soil Sensor - Grasslands and Pastures, Soil Rapid Testing
  • Power consumption: 0.7W@24V
  • Output mode: RS485
  • Detection parameters: Temperature, Humidity, Electrical Conductivity (EC)
  • Humidity parameters
              Measuring range: 0-100%
              Resolution: 0.1%
  • Temperature parameters
              Measuring range: -40°C~+80°C
              Resolution: 0.1°C
              Accuracy: ±0.5°C
  • EC parameters
              Measuring range: 0-20000us/cm
              Resolution: 1us/cm
              Accuracy: 0-10000us/cm@±3%FS, 10000-20000us/cm@±5%FS
              Temperature compensation: memory temperature compensation, compensation range 0-50°C
  • Protection level: IP68
  • Working temperature: -40°C~+60°C
  • Cable length: 2m
  • Size: 123*45*15mm
  • RS485 Soil Sensor (Temperature&Humidity&EC) x1
    Jan 12, 2025
    Pauli.Hakala Jun 07, 2026
    Good product to start with and continue futher
    Out Of Stock
