LattePanda Mu Micro x86 Compute Module Evaluation Kit (N100, 8GB RAM, 64GB eMMC)
$229.00
SKU: KIT0200
Notice: Limited to 20 pieces per customer.
The x86 Compute Module Kit offers a compact, powerful solution for prototyping and hardware development, featuring flexible expansion options and multi-OS support.
Purchase this product and earn 1145 reward points, which are tied to VIP membership program. Learn More >
The LattePanda Mu x86 Compute Module Evaluation Kit is a comprehensive development kit designed for hardware developers. It includes the LattePanda Mu - A Micro x86 Compute Module (N100 CPU,8GB RAM,64GB eMMC), Lite Carrier Board, and Active Cooler. This kit is suitable for evaluating common interfaces such as USB, HDMI, PCIe, UART, and can be used for solution evaluation, prototype design, and more. It provides abundant open-source design materials to accelerate development progress and make hardware development more efficient and convenient.
Product 1 in this Kit - A Micro x86 Compute Module (N100 CPU,8GB RAM,64GB eMMC)
Small but Powerful
LattePanda Mu x86 compute module features Intel N100 quad-core processor with 3.4GHz turbo frequency, offering ample performance and multitasking capabilities for the majority of applications.
Equipped with an Intel Processor N100, LattePanda Mu compute module offers a multi-core score of 3115 and a single-core score of 1217 on Geekbench 6, outperforming the Raspberry Pi 5, Intel Celeron N5105, and Atom x5-Z8350. Its CPU performance doubles the Raspberry Pi 5.
Overview of LattePanda Mu (N100,8GB RAM,64GB eMMC) Kit
Card-Sized
Despite its small size of 69.6mm x 60mm, the pocket size of the LattePanda Mu computer-on-module allows for integration into space-constrained devices, delivering powerful computation without occupying much space.
Card Size of LattePanda Mu Micro x86 Compute Module
Flexibility in Performance and Energy
The processor's TDP can be adjusted from 6W to 35W, providing flexibility in power usage and heat output. The 6W setting enables efficient operation with minimal heat and silent passive cooling, while the 35W setting offers robust performance but requires active cooling.
Flexibility in Performance and Energy of LattePanda Mu Micro x86 Compute Module
Flexible Expansion Pins
LattePanda Mu compute module exposes extensive pins, such as 3 HDMI/DisplayPort, 8 USB 2.0, up to 4 USB 3.2, 9 PCIe 3.0 lanes, 2 SATA 3.0 and 64 expandable GPIOs. This offers unparalleled flexibility and expandability, allowing you to create the specific solution.
Flexible Expansion Pins of LattePanda Mu Micro x86 Compute Module
Multi-System Support
LattePanda Mu x86 computer-on-module supports multiple operating systems, including Windows 10, Windows 11, Ubuntu, ensuring that there is always one that suits your needs.
LattePanda Mu Micro x86 Compute Module support Windows 10, Windows 11, Ubuntu
Making Carrier Simpler and Easier
LattePanda Mu x86 compute module offers open-source carrier board files and libraries as reference materials, enabling you to fine-tune the carrier board design to meet your specific needs, significantly reducing development time.
Open-source carrier board files and libraries
LattePanda Mu Micro x86 Compute Module Making Carrier Simpler and Easier
Customized Solutions
LattePanda Team offers customized services, including customized carrier boards, boot screens, BIOS functionality, operating systems, etc. If you have any specific requirements, please feel free to contact us at [email protected].
The LattePanda Team is dedicated to providing timely and professional support to meet your customization needs.
Customized Solutions of LattePanda Mu Micro x86 Compute Module
Product 2 in this Kit - Lite Carrier Board for LattePanda Mu
Interfaces Integrated Common Interfaces
This lite carrier board includes USB 3.0, Ethernet, PCIe 3.0, M.2 M key, M.2 E key, HDMI, etc. Its comprehensive integration design and compact size make it more convenient to use and cost-effective.
Wide Voltage Input
This lite carrier board supports a wide voltage input of 12~20V, allowing direct connection to a 4S lithium battery without the need for an additional voltage regulator module. This wide voltage input design greatly enhances the product's adaptability and portability.
PCIe 3.0 x4 Expansion Slot
This lite carrier board is equipped with a standard PCIe 3.0 x4 slot, allowing you to easily expand various peripherals, such as graphics cards, sound cards, network cards, etc., providing more powerful performance for your project (this interface is only available when paired with a 12V power supply).
M.2 Expansion Slot
In addition to the PCIe slot, this carrier board also comes with M.2 M key 2230 and M.2 E key 2230 slots, which can easily expand SSD hard drives and WLAN wireless network cards, bringing more possibilities to your project.
3.5-inch Standard Size
This lite carrier board uses the standard size of 3.5-inch embedded motherboards, which is extremely convenient for installation and pairing with other devices. This standardized design allows it to seamlessly integrate into your various projects and systems.
Product 3 in this Kit - LattePanda Mu Active Cooler
The LattePanda Mu Active Cooler is a high-quality cooler designed specifically for the LattePanda Mu compute module. It allows for perfect integration between LattePanda Mu and the carrier board, enabling you to freely build various DIY projects. This low-noise fan ensures stable temperature for your LattePanda Mu, and the heat dissipation fins quickly absorb the heat generated by the CPU. This simple yet effective method keeps your LattePanda Mu in its best condition at all times! The aluminum alloy housing has excellent thermal conductivity and comes with high-quality phase change materials for even better heat dissipation performance.
  • Active cooling aluminum alloy heatsink
  • Aluminum alloy material, corrosion-resistant and durable
    LattePanda Mu Compute Module
  • Processor: Intel Processor N100 4 Cores up to 3.4GHz
  • Memory: LPDDR5 4800MT/s 8GB with IBECC supported
  • Storage: eMMC 5.1 64GB
  • Display: 3 Ouputs; Max Resolution 4096 x 2160@60Hz
  • I/O
                 PCIe 3.0: up to 9 lanes
                 SATA 3.0: up to 2 ports
                 USB 3.2 (10Gbps): up to 4 ports
                 USB 2.0 (480Mbps): 8 ports
                 I2C, UART and GPIOs
  • Power: 9~20V
  • Operating System: Windows, Ubuntu
  • Environment: 0~60°C; 0~80% relative humidity
  • Size: 69.6 x 60mm
  • Lite Carrier Board for LattePanda Mu
    Power Input
  • USB Type-C: 15V (Max 3A)
  • DC 5.5x2.5mm: 12~20V (Max 10A)
  • Internal Interfaces
  • PCIe 3.0 x4 slot (only available when using 12V power supply)
  • M.2 M Key 2230 (PCIe 3.0 x1)
  • M.2 E Key 2230 (PCIe 3.0 x1, USB2.0)
  • RTC battery socket (CR1220 3V)
  • CPU fan socket
  • Gravity-4P UART
  • Gravity-4P I2C
  • MX1.25-10P Connector (for LattePanda UPS Expansion board)
  • External Interfaces
  • USB 3.2 10Gbps x2
  • Gigabit Ethernet
  • USB 2.0 x2
  • HDMI 2.0
  • USB Type-C (for power supply only)
  • DC 5.5x2.5mm
  • Size: 3.5 inches, 146mm×102mm
  • LattePanda Mu Active Cooler
  • Compatible: LattePanda Mu
  • Operating voltage: 5V
  • Operating current: 0.35A
  • Maximum rotational speed: 4000 RPM
  • Wire length: 105mm
  • Interface type: PH2.0-4P
  • Dimensions: 69.6 * 50.4 * 19mm
  • Material: Aluminum alloy
  • Weight: 69g
  • LattePanda Mu Compute Module (N100 CPU,8GB RAM,64GB eMMC) x1
  • Product Manual x1
  • Lite Carrier board x1
  • Acrylic Base Plate x1
  • Screw Pack for Lite Carrier board x1
  • CR1220 Button Battery x1
  • LattePanda Mu Active Cooler x1
    The COOLEST Mini PC - It Games!
    Media The COOLEST Mini PC - It Games!
    Toasty Bros
    Feb 10, 2025
    Andrew.Wickens Jan 24, 2026
    Excellent evaluation kit for x86 embedded projects. The LattePanda Mu N100 evaluation kit is very well designed and makes it easy to work with the compute module. Performance is excellent for its size, with good Linux and Windows support. The carrier board exposes useful interfaces, setup is straightforward, and it’s ideal for prototyping custom hardware, compact PCs, or handheld-style projects. Highly recommended for developers and makers.
    Tezel.Celebi Dec 18, 2025
    Excellent product. We have started development in 10 minutes after unpacking the product.
