M.2 (B+M Key) to 5G Ethernet Network Card for LattePanda (Supports Windows 10 / 11, Linux)
$31.90
SKU: FIT1007
  • $31.00 3+ items
  • $30.50 5+ items
  • $30.00 10+ items
The M.2 to 5G Ethernet Network Card converts an M.2 slot to a 5G Ethernet port, supporting up to 5Gbps data rates, compatible with Windows, Linux, and macOS.
Purchase this product and earn 319 reward points, which are tied to VIP membership program. Learn More >
The M.2 to 5G Ethernet Network Card is an advanced networking solution designed to upgrade network connectivity by converting an M.2 B+M Key slot into a high-speed 5G Ethernet RJ45 port. Powered by the RTL8126 chipset, this network card supports adaptive data rates of up to 5Gbps, providing superior performance for demanding network environments. It is fully compatible with Windows 10/11, Linux, and macOS systems, making it an ideal choice for systems like the LattePanda Alpha / LattePanda 3 Delta, and LattePanda Sigma single board computers. The card supports multiple network standards, including IEEE 802.3, IEEE 802.3u, and IEEE 802.3ab, and is perfect for high-performance applications such as smart computing, network expansion, and soft routing.
For customers requiring higher-speed networking (up to 5Gbps) and dealing with larger data throughput demands, the M.2 to 5G Ethernet Network Card is the preferred option.
Board Overview of M.2 to 5G Ethernet Network Card
High-Speed 5G Ethernet Performance
Equipped with the RTL8126 chipset, the M.2 to 5G Ethernet Network Card delivers impressive data rates of up to 5Gbps, ensuring smooth and stable high-speed connectivity. This makes it ideal for bandwidth-intensive applications such as HD video streaming, data transfer, and advanced network configurations. The card supports a wide range of adaptive speeds (5G, 2.5G, 1G, and 10Mbps) to automatically match the network's infrastructure for optimal performance.
Broad Compatibility Across Multiple Operating Systems
The network card is compatible with Windows 10/11, Linux, and macOS, providing seamless integration across various platforms. Whether you're using a compact PC, laptop, or IoT device, this card ensures that your system can easily expand its networking capabilities without requiring additional setup. It's designed to work flawlessly with LattePanda Alpha, 3 Delta, and Sigma motherboards, offering convenient plug-and-play functionality.
Wiring Diagram of LattePanda Sigma and M.2 to 5G Ethernet Network Card
Wiring Diagram of LattePanda 3 Delta and M.2 to 5G Ethernet Network Card
Wiring Diagram of LattePanda Alpha and M.2 to 5G Ethernet Network Card
Durable and Energy-Efficient Design
With a low power consumption of just 1.7W, this network card offers energy-efficient performance without sacrificing connectivity speed or reliability. Its durable construction allows it to operate within a wide temperature range (from 0°C to 70°C) and withstand harsh environments, making it a reliable choice for industrial and home networking applications alike.
LattePanda Ethernet Network Card Selection Guide
  • LattePanda 5G Network Expansion
  • Chipset: Realtek RTL8126
  • Interface: M.2 B+M Key
  • Transmission Rate: 5G/2.5G/1G/100Mbps/10Mbps (adaptive)
  • Network Standards: IEEE 802.1P, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
  • Network Interface: RJ45
  • Supported Operating Systems: Windows 10/11, Linux, macOS
  • Operating Temperature: 0°C to 70°C
  • Storage Temperature: -55°C to 125°C
  • Power Consumption: 1.7W
  • Cable Length: 250 mm
  • M.2 Board Dimensions: 22 mm x 80 mm
  • RJ45 Board Dimensions: 38 mm x 25 mm
  • M.2 (B+M Key) network card x1
  • 5G Ethernet port x1
  • Data cable x1
  • Short iron piece x1
    Only 9 Left
