URM37 V5.0 is a powerful ultrasonic sensor module with built-in temperature compensation to ensure accurate distance measurement in the scene of temperature-changing applications. It has a rich interface and offers various outputs: analog output, switch, serial (TTL and RS232 level optional), PWM, and so on. With analog mode, the sensor outputs voltage which is proportional to distance, it can be connected to Arduino, Raspberry Pi, and LattePanda(windows 10 development board). The module can be used to measure the rotation angle of the servo. Connected with an external servo, it changes into a spatial ultrasonic scanner. URM37 has been on the market for many years and plays an important role in various fields, and we are constantly optimizing and improving it. The mechanical size, pin interface, and communication commands of this version(V5.0)are compatible with older versions. Based on the old version, the following improvements have been made:
URM37 V5.0 Ultrasonic sensor, the current version has better intelligence capabilities, meanwhile, mechanical dimensions and pin interface and communication commands are compatible with V4.0:
Caution: The ultrasonic sensor has high sensitivity, which may lead to inaccurate readings in complex or low-lying environments. For precise measurements, use the sensor in an open environment like outdoors. The diagram illustrates the sensor's beam angle to aid in understanding and selecting suitable application scenarios.
URM37 Ultrasonic Distance Sensor Beam Angle
Dec 11, 2025
very nice product, it's very good
Oct 22, 2025
Rock solid via UART. Works as advertised. Would recommend.
May 31, 2025
I can use Raspberry Pi with python code easily
