Gravity: Digital Crash Sensor (Right)
$1.90
SKU: SEN0138-R
Miniature micro switch sensor for Arduino with onboard LED and pull-up resistor. Compatible with Micro:bit. Applications include safety switches and fault detection.
Purchase this product and earn 19 reward points, which are tied to VIP membership program. Learn More >
A miniature snap-action switch, also trademarked and frequently known as a micro switch, is an electric switch that is actuated by very little physical force.Micro switches are very widely used; among their applications are appliances, machinery, industrial controls, vehicles, and many other places for control of electrical circuits. They are usually rated to carry current in control circuits only, although some switches can be directly used to control small motors, solenoids, lamps, or other devices.
 This is a small micro switch crash sensor designed for the Arduino. It could be directly connected to the IO Expansion shield. It integrates the pull-up resistor and the status indicator LED onboard. That makes it easier for testing.The miniature snap-action micro switch with roller lever make it suitable for more different environment application.
Now it comes the upgraded version that it can be compatible with Micro:bit.
  • Levelling and safety switches in elevators
  • Door interlock on a microwave oven
  • Vending machines
  • Detect paper jams or other faults in photocopiers
  • 3D Printer position feedback,etc...
  • Working Voltage: 5v
  • Pinout:
    • 1 Digital output
    • 2 VCC
    • 3 GND
  • Onboard status indicator LED
  • Directly connected to the IO Expansion shield For Arduino
  • M3 mounting hole x2
  • Size: 30x20x8mm (1.18x0.79x0.31")
  • Crash sensor x1
How To DIY a Robot with Function of Gap Avoidance
Blog How To DIY a Robot with Function of Gap Avoidance
Jun 23, 2016
