Gravity: Analog Rotation Potentiometer Sensor for Arduino - Rotation 3600°
$3.40
SKU: DFR0058
This multi-ring rotation sensor offers accurate readings, rotating up to 10 laps. It's compatible with Arduino, Raspberry Pi, Intel Edison, Joule, and Curie.
Purchase this product and earn 34 reward points, which are tied to VIP membership program. Learn More >
This Arduino Rotation Potentimeter Sensor is a multi-ring rotation sensor. It is based on multi-turn precision potentiometer. It can rotate upto 10 laps. The voltage can be subdivided into 1024 copies. This sensor provides a more accurate reading.
This is sensor can also be used as a simple encoder if the rotation degree is not over 3600 degree.
Gravity(sensors, shield and modules for Arduino) Interface is adapted to allow plug&play.  The IO Sensor Expansion Shield is the best match for this sound senor connecting to your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Piintel edison, joule and curie.
DFRobot Arduino Rotation Potentiometer Sensor Diagram
  • Rotation Potentimeter  Sensor V2x1
  • Analog Sensor Cable x1
Only 11 Left
