LED Current Meter 50A (Green)
$7.20
SKU: DFR0245-G
  • $7.10 2+ items
  • $6.90 5+ items
  • $6.50 10+ items
This LED Current Meter measures 0-50A with 2% accuracy, offers reversed connection protection, and features a dual-color LED display. It requires careful wiring.
Purchase this product and earn 72 reward points, which are tied to VIP membership program. Learn More >
Note: The product has two kinds of chips (STM8S003F3P6 and STM8S003F3U6-QFN) and will be randomly selected to deliver to you.
This is a standard LED Current Meter 50A. The biggest feature is that the LED Current Meter have reversed connection protection to prevent from being burnted out. It measures 0-50A with 2% error. Best suitable for current display in the circuit. Just apply four wires without any extra circuit or components, you will get the readings displayed straight away.  Easy to use, and good company with robot applications. It has two color LED display to select, green/red.
Warnings: Please carefully follow the instructions for wiring. The power supply terminal and measurement terminal of this Current Meter are using the same common-ground connect. So, the measurement terminal of current meter must be cascaded after load. The measurement terminal must be link to the ground side, Do NOT link it to positive side, it will damage the meter permently.
  • Various circuits
  • Measure Current: 0-50A DC
  • Power supply voltage: 4-30V DC
  • Display mode: 3-bit 0.56 Led digital tube
  • Accuracy:2%
  • Opening dimension: 45.5mm*26.5mm (1.79"*1.04")
  • Dimension: 48mm*29mm*21mm (1.89"*1.14"*0.83")
  • LED Current Meter 50A  x1
  • shunt  x1
Only 2 Left
