SELECTION GUIDE DFRobot
DFRobot Jun 25 2022 272191
What is Gas Sensor?
Gas sensors are mainly used for the detection of a specific gas, measuring the presence or absence of that gas in the sensor's vicinity or the amount of air in the sensor's vicinity.
Therefore, gas sensors are often indispensable in safety systems, where they can provide information on flammable, combustible and toxic gases, as well as the consumption of oxygen in the area, the percentage of carbon dioxide, etc. The common gas sensors available today can be classified according to the detection principle: electrochemical gas sensors, semiconductor gas sensors, infrared gas sensors, MEMS gas sensors,etc.
Characteristics of different principles
Electrochemical Gas Sensors: very low power consumption, high stability, high precision, susceptible to interfering gases, susceptible to temperature changes
Semiconductor Gas Sensors: low price, fast response, poor linearity difficult to measure specific values, susceptible to interfering gases, susceptible to temperature changes.
Infrared Gas Sensors: high stability, strong anti-interference ability, long life, can not be used in dusty and humid environment, higher price.
MEMS Gas Sensors: miniaturization, low power consumption, general accuracy
Oxygen / O2 Sensor
Product Name
Gravity: Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C)
Gravity: Factory Calibrated Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C & UART)
Gravity: Electrochemical Oxygen / O2 Sensor (0-100%Vol, I2C)
Figure
SKU
SEN0322
SEN0465
SEN0496
Quick start oxygen measurement
High precision, high stability
Full range oxygen concentration
3.3V, 5V; 0~25%; Electrochemical
3.3V, 5V; 0~100%; Electrochemical
Add to Cart
Add to Cart
Add to Cart
Carbon Dioxide / CO2 Sensor
Product Name
Gravity: Analog Electrochemical Carbon Dioxide Sensor (0-10000 ppm)
Gravity: PWM Infrared Carbon Dioxide Sensor (400-5000 ppm)
Gravity: UART Infrared Carbon Dioxide Sensor (0-50000 ppm)
Figure
SKU
SEN0159
SEN0219
SEN0220
Carbon Dioxide Leak Warning
Accurate measurement of gas concentration
Large range, special environment can also be used
3.3V, 5V; Qualitative analysis; Electrochemical
5V; 400~5000ppm; Infrared
4.5V, 5.5V; 400~50000ppm; Infrared
Add to Cart
Add to Cart
Add to Cart
Carbon Monoxide / CO Sensor
Product Name
Gravity: Analog CO Sensor (MQ7)
Gravity: CO Sensor (Calibrated) - I2C & UART
Figure
SKU
SEN0132
SEN0466
Slogan
Carbon Monoxide Leak Warning
5V; Qualitative analysis; Semiconductor
3.3V, 5V; 0~1000ppm; Electrochemical
Add to Cart
Add to Cart
Add to Cart
Ozone / O3 Sensor
Product Name
Gravity: Electrochemical Ozone Sensor (0-10 ppm, I2C)
Gravity: O3 Sensor (Calibrated) - I2C & UART
Figure
SKU
SEN0321
SEN0472
Slogan
Factory calibrated, compact size
3.3V, 5V; 0~10ppm; Electrochemical
Add to Cart
Add to Cart
Add to Cart
Alcohol Sensor
Product Name
Gravity: Analog Alcohol Sensor (MQ3)
Gravity: Alcohol Sensor - I2C&UART
Figure
SKU
SEN0128
SEN0376
Slogan
Alcohol Leak Warning
3.3V, 5V; 0~5ppm; Electrochemical
Add to Cart
Add to Cart
Add to Cart
Hydrogen / H2 Sensor
Product Name
Gravity: Analog Hydrogen Gas Sensor (MQ8)
Gravity: H2 Sensor (Calibrated) - I2C & UART
Figure
SKU
SEN0133
SEN0473
Slogan
Hydrogen Leak Warning
Add to Cart
Add to Cart
Add to Cart
Sulfur Dioxide / SO2 Sensor
Product Name
Fermion: MEMS Gas Sensor - MiCS-2714
Gravity: SO2 Sensor (Calibrated) - I2C & UART
Figure
SKU
SEN0441
SEN0470
Time of Each Measurement
Compact size for easy integration
Distance Measurement Resolution
3.3V, 5V; 0.05~10ppm; MEMS
3.3V, 5V; 0~20ppm; Electrochemical
Add to Cart
Add to Cart
Add to Cart
Other Toxic Gas Sensors
Product Name
Gravity: Factory Calibrated Electrochemical Nitrogen Dioxide Sensor (0-20ppm, I2C&UART)
Gravity: H2S Sensor (Calibrated) - I2C & UART
Gravity: HF Sensor (Calibrated) - I2C & UART
Gravity: NH3 Sensor (Calibrated) - I2C & UART
Gravity: CL2 Sensor (Calibrated) - I2C & UART
Gravity: PH3 Sensor (Calibrated) - I2C & UART
Gravity: HCL Sensor (Calibrated) - I2C & UART
Figure
SKU
SEN0471
SEN0467
SEN0475
SEN0469
SEN0468
SEN0476
SEN0474
3.3V, 5V; 0~20ppm
3.3V, 5V; 0~100ppm
3.3V, 5V; 0~10ppm
3.3V, 5V; 0~100ppm
3.3V, 5V; 0~20ppm
3.3V, 5V; 0~1000ppm
3.3V, 5V; 0~10ppm
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
(Electrochemical principle,High precision, High stability)
Composite Combustible Gas Sensors
Product Name
Gravity: Analog CH4 Gas Sensor (MQ4) For Arduino
Gravity: Analog LPG Gas Sensor (MQ5) For Arduino
Gravity: Analog Gas Sensor (MQ2)
Gravity: Analog Propane Gas Sensor (MQ6)
Gravity: Analog CO/Combustible Gas Sensor (MQ9)
Figure
SKU
SEN0129
SEN0130
SEN0127
SEN0131
SEN0134
Slogan
Sensitive detection of methane, natural gas
Sensitive detection of butane, propane and methane
Sensitive detection of liquefied gas, propane, hydrogen
Sensitive detection of propane, butane, LPG
Sensitive detection of carbon monoxide, methane, LPG
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
Add to Cart
(Semiconductor Principle/ Simultaneous detection of multiple gases/ Used for leak warning)
Composite Toxic Gas Sensor
Product Name
Gravity: MEMS Gas Sensor (CO, Alcohol, NO2 & NH3) - I2C - MiCS-4514
Fermion: MEMS Gas Sensor - MiCS-5524 (Breakout)
Figure
SKU
SEN0377
SEN0440
Slogan
Formaldehyde, ethanol, hydrogen, ammonia, carbon monoxide, nitrogen dioxide concentration detection
Formaldehyde, ethanol, hydrogen, ammonia, carbon monoxide concentration detection
Add to Cart
Add to Cart
Add to Cart
