SELECTION GUIDE
Building a Continuous Water Quality Monitoring System? Meet the New RS485 Sensor Series
DFRobot May 13 2026 1614
Building a reliable, continuous water quality monitoring system usually forces you to make a difficult choice: either buy expensive, closed-ecosystem industrial sensors with poor documentation, or use low-cost hobbyist sensors that drift and degrade when deployed outdoors.
To bridge this gap for our maker and engineering community, we have carefully curated and introduced a powerful new collection of 11 Industrial-Grade RS485 Water Quality Sensors to dfrobot store. Handpicked specifically for edge monitoring, this series connects professional-grade industrial durability with the accessible Arduino and ESP32 ecosystems.
From standard pH and Conductivity nodes to advanced Ecological telemetry (Chlorophyll, Optical Dissolved Oxygen, and Blue-Green Algae), this curated lineup provides everything you need to build robust, distributed water monitoring stations.
Why Upgrade to RS485 / Modbus RTU for Water Monitoring?
If you have ever deployed analog sensors in the field, you know the pain points: signal degradation over long cables, electromagnetic interference, and the need for complex calibration circuits.
Here is why this new RS485 series solves these engineering challenges:
  • RS485 vs. Analog: Unlike analog signals, the RS485 differential signal is highly resistant to noise and allows for long cable runs (our sensors come with a standard 5m cable, extendable if needed). This is crucial for remote outdoor ponds or large wastewater facilities.
  • Daisy-Chaining (Modbus RTU): You can connect multiple sensors (e.g., pH, Turbidity, and Dissolved Oxygen) onto a single RS485 bus. This significantly simplifies your IoT node architecture, requiring fewer GPIO pins on your microcontroller.
  • Built-in Temperature Compensation: Conductivity, DO, and pH readings drift significantly with temperature changes. Every sensor in this series features an integrated temperature sensor and internal algorithms to automatically compensate for these variations, ensuring stable data in fluctuating environments.
  • IP68 Submersible Durability: With an integrated probe and corrosion-resistant housing (some featuring robust 316 stainless steel), these sensors are designed for long-term submersion without biofouling destroying the electronics.
Crucially, we provide comprehensive tutorials for connecting these Modbus sensors directly to Arduino boards and DFRobot LoRaWAN nodes, lowering the barrier to entry for industrial IoT.
Sensor Selection Guide by Application
To help you configure your monitoring system, we have categorized the 11 new sensors based on common deployment scenarios:
1. Aquaculture, Mariculture & Hydroponics
Monitoring chemical balance and oxygen availability is critical for aquatic survival and plant health.
Optical Dissolved Oxygen (DO) Sensors: Traditional electrochemical sensors require constant electrolyte and membrane replacement. Our new Fluorescence DO sensors utilize an optical phase-shift method that does not consume oxygen and requires virtually zero maintenance.
2. Wastewater Treatment & Industrial Effluent
Harsh environments require sensors that can handle extreme variables and heavy biological loads.
3. Swimming Pool Automation & Tap Water
Ensuring public health and safety through continuous sanitation tracking.
4. Ecological, River & Lake Telemetry
For researchers monitoring natural water bodies, estuary environments, and preventing harmful algal blooms (HABs):
From Sensor to Dashboard: The Architecture
With these sensors, building a professional telemetry node is straightforward:
  • Sensing: Deploy the RS485 sensors in the water body.
  • Edge Processing: Connect the RS485 bus to an Arduino, ESP32, or Raspberry Pi using an RS485-to-TTL shield.
  • Telemetry: Send the Modbus data via Wi-Fi, 4G, or LoRaWAN to your preferred Cloud Dashboard for data logging, alerts, and automation.
All sensors are rigorously calibrated out-of-the-box and support standard register settings for easy recalibration over time.
Ready to build your next-generation water monitoring node? Explore the specifications, wiring diagrams, and sample codes for the entire series in liquid sensors wiki.
