DFRobot Gravity Series is a high quality open-source, modular, plug and play electronics toolkit for everyone to create anything easily. With powerful expansion shields, various professional functional modules with standard interfaces and clear documentations, Gravity Series allows users of any skill level to easily connect and mix to realize ideas or develop projects.
Explore the features, specifications, and applications of Gravity CO2 sensors, including electrochemical, infrared, and photoacoustic NDIR sensors. Choose the right sensor for your needs.
SELECTION GUIDE GravityArduino
Ultrasonic sensors have a wide range of applications in various industries, including security, liquid level detection, and obstacle avoidance. Discover how the URM series of ultrasonic distance measurement modules can meet your business needs and improve efficiency.
SELECTION GUIDE ArduinoGravity
Learn how to design and construct an indoor air quality monitoring system to improve your living environment and protect your health from indoor pollutants.
PROJECTS ArduinoGravityLearn how to make your own gesture universal remote control with DFRobot’s Gravity PAJ7620U2 Gesture Sensor. Control your electrical devices with gestures and custom features.
PROJECTS Gravity
Discover the features of Gravity heart rate monitor sensors for Arduino, including ECG and PPG measurement principles, analog and digital outputs, and power consumption.
SELECTION GUIDE ArduinoGravityLearn how to make a fart tracker with CCS811 air quality sensor, Arduino Nano, and LED module. Follow the steps to create a device that can detect volatile gas and CO2 concentrations.
Selection Guide for Gesture Recognition Sensors
SELECTION GUIDE ArduinoGravityA system of three robots that can be controlled and battled by three different players via a mobile webpage.
PROJECTS RoboticsGravity
In this blog, we will introduce you to all of DFRobot’s liquid sensors and list all their parameters so that you can make a purchase.
SELECTION GUIDE GravityArduinoI want to turn on the light simply by lightly knocking on the table.
TUTORIALS ArduinoGravitySurfing the internet but failed, big clocks take too much space, small ones are hard to check the time. Well, I decide to make my own clock.
PROJECTS ArduinoGravitySolarExtend the functionality of your current keyboard with custom capacitive touch keys.
PROJECTS ArduinoGravityAnother indoor greenhouse powered by Nano. 100% controlled environment with some extra perks that make life easier.
PROJECTS ArduinoGravityWhile the sensor Arduino was being programmed, the buoyancy control Arduino also had to be programmed to control the stepper motor and communicate with the sensor Arduino.
PROJECTS ArduinoGravityThis project details the design and implementation of a novel aquatic robot that uses an autonomous surface vehicle (ASV) and a towed underwater glider (AUV) to capture water quality measurements at multiple depths across a body of water and display those measurements to an onshore user in real-time.
PROJECTS ArduinoGravityRaspberry PiThis project includes hardware which will measure blood pressure, heart rate, ECG & temperature, and send to Android application & Firebase.
PROJECTS IoTArduinoGravityBuild your own lightning detector that's smaller, more customizable, and cheaper than a commercial one!
PROJECTS ArduinoGravityBluetoothDFRobot.com official blog supplies varieties of Raspberry Pi, mini PC, I just got a 7” LCD capacitive touchscreen made by DFRobot.
PROJECTS ArduinoGravityRaspberry PiA WiFi controlled desk light, essential for every maker and a great way to get into coding.
PROJECTS ArduinoGravityESP8266How to make a dress representing Saturn? The planets and satellites light up when the ring appears.
PROJECTS ArduinoGravityA low-cost stick designed for blind people that enables them to walk without any assistance.
PROJECTS ArduinoGravityBluetoothHow to make a Aquarium Water Cooling System
PROJECTS ArduinoGravityBluetoothHow to Make an Arduino Weather Station with DHT11 Sensor
PROJECTS ArduinoGravityAutomated environment for reptiles to promote good husbandry and enable maximum lifespan for animals in captivity.
PROJECTS ArduinoGravityRaspberry PiPage 1 of 4
