Gravity: I2C 16x2 Arduino LCD with RGB Backlight Display V2.0
$11.90
SKU: DFR0464
  • $11.30 5+ items
  • $10.70 10+ items
The 16x2 LCD screen features RGB backlight with 16 million colors, using I2C for easy connection. It operates at 3.3-5V, saving Arduino pins. Dimensions: 87x32x13mm.
Have you been fed up with Black/White LCD screen? Do you want to try a colorful one? DFRobot I2C 16x2 Arduino LCD with RGB Backlight Display module will bring you a new experience about screen. It comes with RGB full color backlight, which has 16 million kinds of color.
Usually, Arduino LCD display projects will run out of pin resources easily, especially with Arduino Uno. And it is also very complicated with the wire soldering and connection. This I2C 16x2 LCD Screen is using an I2C communication interface. It means it only needs 4 pins for the LCD display: VCC, GND, SDA, SCL. It will saves at least 4 digital / analog pins on Arduino. And Gravity interface make it easier to use with our Gravity: IO expansion shield.
I2C 16x2 Arduino LCD with RGB Backlight Display - Introduction
DFR0464 Product Feature
DFR0464 Application Examples
DFR0464 Programming Examples
DFR0464 Programming Sample Codes
DFR0464 Product Display
DFR0464 Product Parameters
DFR0464 - дисплей 2x16 с i2c и RGB-подсветкой
ЖК-дисплей 16x2 с I2C и RGB подсветкой от DFRobot
  • Operating Voltage: 3.3V ~ 5.0V
  • Operating Current: <60mA
  • Display: 16 * 2
  • Communication: I2C
  • Backlight: RGB adjustable backlight (16 million)
  • Operating Temperature: -20 to + 70 ℃
  • Storage Temperature: -30 to + 80 ℃
  • Dimension: 87.0 * 32.0 * 13.0mm/3.42 * 1.26 * 0.51 inches
  • Gravity: I2C 16x2 Arduino LCD with RGB Backlight Display V2.0 x1
  • Gravity 4Pin I2C/UART Sensor Cable x1
    Ionizing Radiation Detector
    Projects Ionizing Radiation Detector
    KGray
    Jun 25, 2024
    Only 6 Left
