micro:bit Expansion Board for Boson (Gravity Compatible)
$7.90
SKU: DFR0521
A pocket-sized microcontroller for beginners to learn coding and electronics, enabling easy DIY digital games and interactive projects. Supports various modules.
micro:bit is a pocket-sized microcontroller designed for kids and beginners to learn coding and electronics, letting them easily bring ideas into DIY digital games, interactive projects, and robotics.
However, on-board I/O rings and crocodile clips sometimes are not handy and safe enough to connect peripherals. To explore more possibilities with micro:bit, we have designed the micro:bit Expansion Board for Boson, a carry-on board that connects to micro:bit via the edge connector.
micro:bit Expansion Board for Boson (Gravity Compatible) Interface
The expansion board comes with 6 fool-proof 3-Pin sockets, compatible with hundreds of DFRobot’s Boson and Gravity modularized electronic blocks, covering most popular digital and analog sensors and actuators, supporting sound, light, and motion interaction.
Click the link to learn more about DFRobot’s Boson module: https://www.dfrobot.com/boson
Click the link to learn more about DFRobot’s Gravity module: https://www.dfrobot.com/gravity
Moreover, the expansion board adds a Gravity: HuskyLens interface and an IIC interface. To ensure a steady current supply for these peripherals, the expansion board can be powered externally through the Micro-USB power port.
micro:bit Expansion Board for Boson (Gravity Compatible) Game:pad
micro:bit Boson game pad
micro:bit Expansion Board for Boson (Gravity Compatible) Connected with heart rate monitor
micro:bit RGB LED heart rate monitor
  • 3-Pin fool-proof connector x 6
  • IIC connector x1
  • Gravity: HuskyLens connector x1
  • External power port and ON/OFF switch
  • DFRobot Gravity and Boson electronic module compatible
  • MicroUSB Power Port Voltage:5V
  • PH2.0 Input/output Voltage: 3.3V
  • Input/output ring Voltage: 3.3V
  • HuskyLens input Voltage:5V
  • Maximum Current: 500mA
  • Working temperature: 0-85 ℃
  • Dimension 80 * 70 mm / 3.15 * 2.76
  • Weight: 48g
  • micro:bit Expansion Board for Boson x 1
  • 200mm fool-proof PH2.0 cable x 6
    Niu.yx
    Feb 11, 2025
    SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
    Projects SCI Plant Monitor: The Smart Way to Track and Analyze Your Plant's Data for Growth
    Danli
    Jun 25, 2024
    A Science Experiment: Conductivity of Salt Solution with micro:bit
    Projects A Science Experiment: Conductivity of Salt Solution with micro:bit
    qianqian.xua
    Feb 04, 2024
    Design4SDGs: Build a Carbon-Neutral and Sustainable City with micro:bit
    Projects Design4SDGs: Build a Carbon-Neutral and Sustainable City with micro:bit
    Danli
    Jan 25, 2024
