Gravity: 37 PCS Sensor Set for Arduino / Raspberry Pi
$119.90
SKU: KIT0150
Sensor kit with 37 modules for interactive projects; includes color, heart rate, shake sensors, RGB LED, display. Supports Arduino/Raspberry Pi, plug-and-play.
Purchase this product and earn 1199 reward points, which are tied to VIP membership program. Learn More >
Go interactive with your applications with this new sensor kit! 37 sensors are included in one kit, which definitely gives you a bigger bang for your buck.
In the version of this sensor kit, we add more sensor modules like, color sensor, digital wattmeter, heart rate monitor sensor, conductivity sensor switch, and digital shake sensor. Besides that, there are RGB LED module, speaker, vibration motor module, DC motor module and RGB backlight display to help you build up your interactive projects.
Use a variety of sensors to realize your brilliant idea! All of our sensors employ Gravity standard interface, plug and play, also we have a huge amount of code data for your reference. Plug everything in our IO expansion board, burn the codes into it, and then you are ready to go.
With everything included in this kit, you will be able to sense color, heart rate, light, temperature, gas, humidity, flame, direction or let you project speak, shine, and display text. It can almost meet all your needs but the price is more favorable!
This sensor kit supports the Raspberry Pi and  Arduino Programming platform as well as visual programming software like mind+, you can get started easily with them!
Welcome to visit our Mind+ forum to share your opinion with us or go to our blog to find more ways to play!
To help you build projects easily, we have several expansion boards for you to choose, click to the link to buy:
Gravity IO Expansion Shield for Arduino V7.1
FireBeetle Covers-Gravity I/O Expansion Shield
Raspberry Pi 4 Module B-2GB
IO Expansion HAT for Raspberry Pi 4B/3B+
  • Gravity Interface, plug and play, easy to use
  • More sensors and actuators, more ways to play
  • High quality and durable products with elaborate design
Information Recognition
  • Color Sensing
  • Heart Rate Monitoring
  • Sound Sensing
  • Distance Detecting
  • Magnetic Force Sensing
  • Acceleration Sensing
  • Vibration Sensing
  • Touch Sensing
  • Gas Sensing
  • Pressure Sensing
  • Temperature Sensing
  • Humidity Sensing
  • Voltage/Current Sensing
  • Angle Sensing
  • Gravity Sensing
  • Flame Sensing
  • Liquid Sensing
Information Expression
  • Sound
  • Light
  • Wind
  • Display
KOUBELAN RICHARD.AKPAGNI Jul 13, 2023
This is a good product. I like
