In the version of this sensor kit, we add more sensor modules like, color sensor, digital wattmeter, heart rate monitor sensor, conductivity sensor switch, and digital shake sensor. Besides that, there are RGB LED module, speaker, vibration motor module, DC motor module and RGB backlight display to help you build up your interactive projects.
Use a variety of sensors to realize your brilliant idea! All of our sensors employ Gravity standard interface, plug and play, also we have a huge amount of code data for your reference. Plug everything in our IO expansion board, burn the codes into it, and then you are ready to go.
With everything included in this kit, you will be able to sense color, heart rate, light, temperature, gas, humidity, flame, direction or let you project speak, shine, and display text. It can almost meet all your needs but the price is more favorable!
This sensor kit supports the Raspberry Pi and Arduino Programming platform as well as visual programming software like mind+, you can get started easily with them!
Welcome to visit our Mind+ forum to share your opinion with us or go to our blog to find more ways to play!
To help you build projects easily, we have several expansion boards for you to choose, click to the link to buy:
Gravity IO Expansion Shield for Arduino V7.1
FireBeetle Covers-Gravity I/O Expansion Shield
IO Expansion HAT for Raspberry Pi 4B/3B+
Jul 13, 2023
This is a good product. I like
