Gravity: Analog Industrial ORP Sensor Meter Pro for Arduino
$129.00
SKU: SEN0464
  • $126.00 3+ items
  • $123.00 5+ items
  • $120.00 10+ items
Upgraded ORP sensor offers 24-hour monitoring using platinum and silver electrodes, ensuring durability and stable readings despite voltage fluctuations.
Purchase this product and earn 1290 reward points, which are tied to VIP membership program. Learn More >
As an upgraded version of Industrial Gravity: ORP Sensor Meter for Arduino, this new generation ORP probe employs platinum indicator electrode and silver-silver chloride reference electrode, which makes it available for 24-hour online ORP monitoring and greatly enhances product durability.
The new signal converter adds a more stable voltage reference so that the sensor readings would be no longer affected by supply voltage fluctuations. Besides, there are screws, copper columns and waterproof connectors included in the accessory packet to help you conveniently build up ORP monitoring system.
Gravity: Analog ORP Sensor PRO
ORP(Oxidation-Reduction Potential) is a measure of the ability of oxidation and reduction of an aqueous solution, which the relative degree of oxidizing or reducing. The unit is mV.
If the oxidation reduction potential is high then chemical oxidation is strong , while if the potential is lower then oxidation is weaker.
The positive potential means that solution shows a certain degree of oxidation, while the negative potential means that solution shows a certain degree of reduction. ORP is an important index of water quality detection, although it can not separate water quality independently, it can be combined with other water quality indexes to reflect the ecological environment better.
  • 24-hour online ORP monitoring
  • ORP monitoring system
    ORP Signal Converter
  • Input Voltage: 5V
  • Input Signal: 0.5V ~ 4.5V
  • Input Interface: 5.08mm/0.20" Pluggable Connector
  • Measuring Range: -2000mV ~ +2000mV
  • Output Interface: PH2.0 - 3Pin
  • Module Size: 42mm×32mm/1.65×1.26"
  • Industrial ORP Probe
  • Indicator Electrode: Platinum
  • Reference Electrode: silver-silver chloride
  • Suitable Temperature: 5-70℃
  • Electrode Potential: 245mV ~ 270mV
  • Reference Electrode Internal Resistance: ≤10KΩ
  • Electrode Stability: ±8mV/24h
  • Gravity: Analog ORP Signal Converter x1
  • Industrial ORP Probe x1
  • Waterproof Aviation Cable Connector x1
  • Waterproof Cable Gland x1
  • Nylon Screw x1
  • Nylon Column x1
    How to Choose the Right ORP Sensor: From Maker Projects to Industrial IoT
    Blog How to Choose the Right ORP Sensor: From Maker Projects to Industrial IoT
    Apr 08, 2026
    May 18, 2022
    KANATORN.Jindarak Jan 07, 2026
    Good quality, sheep, fast shipping
    Muhammad Fadil.Huseiny Nov 05, 2025
    Good working stable as intended
    Muhammad Fadil.Huseiny Oct 30, 2025
    Really Good, product working well
