Gravity: CL2 Sensor (Calibrated) - I2C & UART
$136.90
SKU: SEN0468
  • $133.00 3+ items
  • $130.00 5+ items
  • $126.00 10+ items
A sensor detects chlorine concentration with analog, I2C, and UART outputs, featuring high sensitivity, anti-interference, and compatibility with Arduino and similar devices.
Purchase this product and earn 1369 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects chlorine concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of chlorine in the environment. Can be widely used in the detection of chlorine in the chemical, pharmaceutical production, and environmental protection fields.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a chlorine concentration detector.
  • High stability
  • High sensitivity
  • Chemical chlorine detection
  • pharmaceutical production chlorine detection
  • Detection Gas: Chlorine (CL2)
  • Detection range: 0~20ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: Chlorine Signal Conversion Board x1
  • Chlorine sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    Only 12 Left
