Gravity: HCL Sensor (Calibrated) - I2C & UART
$167.90
SKU: SEN0474
  • $163.00 3+ items
  • $160.00 5+ items
  • $155.00 10+ items
A sensor for detecting hydrogen chloride concentrations, featuring analog, I2C, and UART outputs, high sensitivity, stability, and compatibility with Arduino.
Purchase this product and earn 1679 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects hydrogen chloride concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of hydrogen chloride in the environment. Can be widely used in the detection of hydrogen chloride in the industrial, underground, and environmental protection fields.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a hydrogen chloride concentration detector.
  • High stability
  • High sensitivity
  • Industrial hydrogen chloride detection
  • Underground hydrogen chloride detection
  • Detection Gas: Hydrogen chloride (HCL)
  • Detection range: 0~10ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: HCL Signal Conversion Board x1
  • HCL sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    Only 19 Left
