Gravity: PH3 Sensor (Calibrated) - I2C & UART
$248.90
SKU: SEN0476
  • $241.00 3+ items
  • $237.00 5+ items
  • $229.00 10+ items
A sensor that detects phosphine concentration using analog, I2C, and UART outputs. Features strong anti-interference, high sensitivity, and a 2-year lifespan.
Purchase this product and earn 2489 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects phosphine concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of phosphine in the environment. Can be widely used in the detection of phosphine in the fields of industry, mining, and environmental protection.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a phosphine concentration detector.
  • High stability
  • High sensitivity
  • Industrial phosphine detection
  • Mining phosphine detection
  • Detection Gas: Phosphine (PH3)
  • Detection range: 0~1000ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: PH3 Signal Conversion Board x1
  • PH3 sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    Only 12 Left
