The C1001 60GHz mmWave Sensor is designed for reliable indoor fall detection and human presence monitoring, making it ideal for elderly care, smart homes, and safety systems. It can detect human presence, falls, breathing, and subtle body movements—even when a person remains completely still. Unlike camera-based solutions, it operates entirely without capturing images, ensuring privacy-safe monitoring in sensitive environments such as bedrooms and bathrooms.
Easy to use with built-in algorithms, the sensor outputs processed detection results directly, eliminating the need for complex radar data analysis. It is compatible with ESP32, micro:bit, and Arduino UNO development boards, this sensor can be easily configured and used with the Arduino IDE.
Integrated Fall Detection Function
The C1001 sensor features a point cloud imaging algorithm that accurately recognizes human postures, including detecting when a person is lying down. It effectively reports fall incidents, the duration of immobility, and periods of physical inactivity. With the ability to detect motion over a wide area (up to 11 meters) when mounted on the ceiling at a height of 2.7 meters, the C1001 ensures precise fall detection. This capability enhances safety monitoring, particularly in elderly care, by providing timely alerts for fall incidents. Unlike other sensors that fail to detect static bodies, the C1001 excels in recognizing both motion and stillness, making it highly reliable.
Comprehensive Sleep Monitoring
In sleep monitoring mode, the C1001 tracks human presence and movement, analyzing variations in body movements and respiratory rates throughout the night. It accurately measures breath frequency and heart rate from a distance of 1.5 meters, offering valuable insights into sleep quality and overall health. By integrating these parameters, the sensor delivers a detailed sleep score, aiding in a better understanding of sleep patterns and health.
Comprehensive Setup and Configuration Support
The C1001 mmWave Human Detection Sensor comes with extensive and detailed usage and configuration tutorials. These guides cover everything from hardware setup to software integration, ensuring smooth implementation and optimal performance. The tutorials include:
Important Disclaimer: This product is not a certified medical device and is not intended to be used as a diagnostic or therapeutic aid. The manufacturer assumes no responsibility for any medical or health-related claims arising from the use of this product. Any reliance on the product for medical purposes is at the user's sole risk and discretion.
Projects C1001 60GHz mmWave Human Detection Sensor with ESP32 | Sleep, Fall & Life Detection
Nov 08, 2025
Excellent 60GHz mmWave sensor — very precise and stable! I tested it with an ESP32 for fall detection and indoor presence monitoring, and the results are impressive. The 11-meter range easily covers large rooms, and it works perfectly even in low-light or completely dark conditions. Setup was straightforward using the provided documentation and sample code. Unlike PIR sensors, it detects motion and falls more accurately without being affected by temperature or lighting. Ideal for smart home and elderly-care IoT applications
Jul 16, 2025
small, compact product, arrived very fast, still to be tested
Jul 03, 2025
thank you. I got it well. the shipping was very quick and safe.
