TF-NOVA Line Laser LiDAR Sensor (14m, Unique Line-Shaped Detection)
$34.90
SKU: SEN0671
  • $34.00 3+ items
  • $33.00 5+ items
  • $32.00 10+ items
A compact LiDAR sensor with 14°×1° detection area, reliable outdoor performance, and interfaces like UART, I2C. Ideal for obstacle avoidance and detection.
Purchase this product and earn 349 reward points, which are tied to VIP membership program. Learn More >
Perceiving the world as a series of disconnected dots, single-point sensors leave vast blind spots and thus often miss critical obstacles. The TF-NOVA Line Laser LiDAR is engineered to eliminate this fundamental flaw. By projecting a wide 14° "curtain" of laser light, it creates a continuous line of detection. At a distance of 1 meter, this line covers an area of 25cm x 1.7cm—perfect for ensuring nothing slips through. This represents a new dimension of perception for automated machines.
TF-NOVA Line Laser LiDAR Overview
Features a unique 14° horizontal by 1° vertical Field of View (FoV), creating a "laser line" of detection. It reliably spots thin objects like chair legs, wires, or pallet edges that single-point sensors would easily miss.
Line-Shaped Detection of TF-NOVA Line Laser LiDAR Sensor
Stable Outdoor Detection
Built on Pulse Time-of-Flight (PToF) technology, the TF-NOVA delivers stable and accurate measurements up to 14 meters, even in 100Klux direct sunlight or on dark, low-reflectivity surfaces.
Unfailing Outdoor Performance of TF-NOVA Line Laser LiDAR Sensor
Incredibly Compact & Lightweight
Smaller than an AA battery and weighing under 5g, its tiny footprint allows for seamless integration into space-constrained and weight-sensitive applications like drones, gimbals, and compact robotics.
Incredibly Compact & Lightweight of TF-NOVA Line Laser LiDAR Sensor
Flexible & Easy Integration
Equipped with UART, I2C, and a configurable I/O mode, it connects directly to platforms like Arduino or Raspberry Pi. The I/O mode can trigger a simple high/low signal, dramatically reducing the main controller's data processing workload.
Class 1 Eye-Safe
The 905nm VCSEL light source is classified as EN60825 Class 1, ensuring safety for use in consumer products, educational settings, and public spaces.
High Update Rate for Dynamic Tasks
With a configurable frame rate up to 900Hz, it can track fast-moving objects or provide real-time feedback for high-speed robotic applications.
  • Robotics: Precision obstacle avoidance for AGVs, service robots, and autonomous mobile robots (AMRs).
  • Industrial Automation: Collision prevention for automatic doors, gates, and elevator systems.
  • Logistics & Warehousing: Pallet and shelf detection for automated shuttle and sorting systems.
  • Drones / UAVs: Altitude holding and terrain following, especially over complex surfaces.
  • Smart Systems: Parking space occupancy detection.
  • Creative Tech: Interactive installations and focus assistance for camera systems.
  • Applications of TF-NOVA Line Laser LiDAR
    Performance Parameter
  • Measurement Range:
           ≥14m@90%reflectivity, 0Klux;  ≥13m@10%reflectivity, 0Klux
           ≥7m@90%reflectivity, 100Klux;  ≥4m@10%reflectivity, 100Klux
  • Blind Zone: 0.1m
  • Accuracy: ±5cm @ 0.1-4m
  • Precision: <1cm (1σ) @ 0.1-4m
  • Distance Resolution: 1cm
  • Frame Rate: 1-900Hz (default: 100Hz)
    Optical Performance
  • Light Source: VCSEL
  • Central Wavelength: 905nm
  • Laser FOV: 14°×1°
  • Laser Safety: Class 1 Eye-safe [EN60825]
    Mechanical & Electrical
  • Avg Power Consumption: 500mW
  • Inrush Current: 850mA
  • Startup Time: 1s
  • Operating Voltage: DC 5V ±5%
  • Operating Temperature: -25℃ ~ +70℃
  • Storage Temperature: -30℃ ~ +80℃
  • Dimensions: 26.5×21.05×12.0mm
  • Weight: 5g
  • Hardware Interface: 1.25mm-5Pin
  • Front Window Protection: IP65
  • TF-NOVA Line Laser LiDAR ×1
  • 1.25mm-to-2.54mm Dupont Cable (20cm) ×1
  • 1.25mm-to-1.25mm Cable (10cm) ×1
  • FAQ
    Only 16 Left
