TFS20-L ToF LiDAR Sensor (20m, Sunlight Resistant, 1.35g)
$43.90
SKU: SEN0672
  • $43.00 3+ items
  • $42.00 5+ items
  • $40.00 10+ items
Lightweight LiDAR sensor for drones and robots offers precise distance measurement up to 20m, with high-frequency data output and strong sunlight resistance.
Purchase this product and earn 439 reward points, which are tied to VIP membership program. Learn More >
Upgrade drone or robot with the Benewake TFS20-L ToF LiDAR sensor. Get precise, centimeter-level distance measurement up to 20 meters, even in challenging 100Klux direct sunlight. Weighing just 1.35g and smaller than a thumbnail, it delivers high-frequency data (up to 250Hz) without impacting your design's weight or balance. It's the perfect high-performance, drop-in solution for UAV altitude hold, robot anti-drop functionality, and reliable obstacle avoidance.
Features of TFS20-L ToF Single-Point Ranging LiDAR Sensor
Feather-light & Fingernail-Sized
Weighing a mere 1.35g and with dimensions of just 21x15x7.87mm, it adds powerful sensing without impacting your drone's flight time or robot's agility.
Compact size of TFS20-L ToF Single-Point Ranging LiDAR Sensor
Exceptional Outdoor Performance
Engineered with 100Klux ambient light resistance, it provides stable and accurate measurements outdoors, even in bright sunlight where other sensors fail.
Long-Range & High-Frequency Sensing
Measures distances up to 20 meters with a configurable frame rate up to 250Hz, enabling real-time navigation and rapid obstacle detection.
Flexible I2C & UART Interfaces
Choose the best communication protocol for project. Easily integrate with virtually any microcontroller, from Arduino and ESP32 to Raspberry Pi.
Fully Integrated & Ready-to-Use
With a built-in power module and temperature compensation, this sensor works reliably out of the box on a simple 3.3V supply, saving development time.
Class 1 Eye-Safe Laser
The 905nm VCSEL light source is certified Class 1, ensuring safety for development, demonstration, and end-user applications.
  • UAV Altitude Hold & Terrain Following
  • Autonomous Drone Assisted Landing Systems
  • Robot Anti-Drop & Edge Detection
  • High-Speed Obstacle Avoidance for AGVs
  • Smart Device Presence Detection & Triggering
  • Industrial Inventory Management (e.g., silo level sensing)
  • Interactive Art Installations
  • Applications of TFS20-L ToF LiDAR sensor
    Performance Parameter
  • Measurement Range: 0.2m – 20m (@90% reflectivity, 0Klux)
         0.2m – 15m (@90% reflectivity, 100Klux)
         0.2m – 9m (@10% reflectivity, 100Klux)
  • Accuracy: ±6cm (@0.2–6m); 1% (@≥6m)
  • Precision (Repeatability): 2cm (0.2–6m)
  • Distance Resolution: 1cm
  • Frame Rate: 0 / 20 / 50 / 100 (default) / 250Hz
  • Ambient Light Resistance: 100 Klux
  • Light Source / Wavelength: VCSEL / 905nm
  • Field of View (FoV): <2°
  • Laser Safety Class: Class 1 Eye-safe [EN60825]
  • Mechanical & Electrical
  • Supply Voltage: DC 3.3V (±9%)
  • Average Power Consumption: ≤0.43W
  • Peak Current: <130mA @ 3.3V
  • Communication Interface: I2C / UART
  • Communication Level: LVTTL (3.3V)
  • Operating Temperature: -20℃ to +60℃
  • Dimensions: 21 × 15 × 7.87mm
  • Weight: 1.35g
  • Hardware Interface: 0.8mm 6-pin Connector (Model: WF08006-01207)
  • TFS20-L ToF Single-Point Ranging LiDAR Sensor ×1
  • 0.8mm to 2.54mm Dupont Connector Cable (20cm) ×1
  • 0.8mm to 0.8mm Connector Cable (8cm) ×1
    Only 18 Left
