TF-UW500 Underwater Single-Point LiDAR for Mapping & Positioning (5m dToF Ranging)
$39.90
SKU: SEN0755
The TF-UW500 is a compact dToF underwater single-point LiDAR providing more than 5m ranging under specified low-turbidity conditions, <3cm accuracy from 0.1 to 2m, 1mm distance resolution, and UART/I2C communication. Designed for underwater robot mapping, positioning, and navigation, the sensor also supports 100Klux ambient-light resistance.
This TF-UW500 underwater single-point LiDAR adopts a dToF (direct Time-of-Flight) solution for precise underwater distance measurement. With a compact 24x16x20.4mm form factor, low average power consumption, and a ranging capability beyond 5m under specified low-turbidity conditions, this underwater LiDAR supports mapping, positioning, and navigation for pool-cleaning and other underwater robots.
Note: This TF-UW500 underwater LiDAR does not include a back cover and has no waterproof protection rating. Waterproof sealing must be incorporated into the external structure during product integration to ensure safe operation underwater.
10× Extended Range for Underwater Perception
Compared with the previous generation, the TF-UW500 increases detection range tenfold in low-turbidity water. The dToF ranging system combines a narrow 0.5° field of view with a Class 1 laser, providing a small optical spot, strong directionality, and a wide usable incidence angle. This optical ranging approach also helps minimize multipath interference compared with traditional ultrasonic sensing.
Centimeter-Level Accuracy for Mapping and Positioning
This underwater LiDAR provides accuracy of < 3cm and repeatability of < 1cm @ 1σ across the 0.1 ~ 2m range, together with 1mm distance resolution. In most residential swimming pools, these ranging capabilities support full-path coordinate positioning and mapping, helping reduce accumulated inertial drift and enabling pool-cleaning robots to maintain straighter and more stable movement paths.
Stable Ranging under Strong Light and Turbid Water
Hardware-level filtering and anti-glare algorithms enable the TF-UW500 to resist ambient light interference up to 100Klux. Calibration across more than 10 common pool materials further supports consistent distance measurement under varying underwater surfaces and water conditions, helping underwater robots maintain smoother navigation in strong light or turbid environments.
  • Underwater ranging range up to 5m
  • Resistant to ambient light interference up to 100Klux
  • Compliant with Class 1 eye-safe visible light lasers
  • Compact size, measuring only 24x16x20.4mm
  • Pool-cleaning robot mapping and positioning
  • Underwater robot navigation
  • Underwater coordinate positioning
  • Underwater distance measurement
    Performance Parameter
  • Underwater ranging range: >5m (indoors, NTU < 0.5, 30% reflectivity, vertical incidence)
  • Blind zone range: ≤ 0.1m
  • Accuracy: < 3cm (0.1 ~ 2m)
  • Repeatability: < 1cm @ 1σ (0.1 ~ 2m)
  • Distance resolution: 1mm
  • Frame rate: Default 20Hz
  • Ambient light resistance: 100Klux
  • Communication interface: UART / I2C (switchable via command)
  • Optical Performance
  • Light source: Laser
  • Center wavelength: Infrared and visible light
  • Field of view: 0.5°
  • Laser safety class: Class 1 (IEC 60825-1:2014; EN 60825-1:2014+A11:2021)
  • Mechanical & Electrical
  • Average power consumption: < 5V@100mA
  • Peak startup current: < 700mA
  • Supply voltage: DC 5±0.2V
  • Serial output: 3.3VTTL
  • Connection terminals: 1.0mm-4P, terminal type HC-1.0-4PWT
  • Operating temperature: 0℃ ~ +50℃
  • Storage temperature: -20℃ ~ +70℃
  • Dimensions: 24x16x20.4mm
  • Weight: < 5g (excluding tail cable)
  • TF-UW500 Underwater Single-Point LiDAR ×1
    Certifications
    Only 15 Left
