DFRobot Forum Logo
HOME COMMUNITY FORUM WIKI BLOG LEARN
Tags FAQSuggestionsHow to selectTroubleshootingGeneral UNIHIKER3D PrintinguPyCraft Bluno PCB ServicesTelematics Mind+Easy IoT RoboticsFirebeetle ESP32/8266HUSKYLENSRaspberry PiGravityLattePandaArduino
Hi, Receiver connected to controller, no TX signal but receives signal. TEL0140TEL0142FAQSEO FAQAftersales FAQ
userHead JaneYu 2026-02-14 08:57:25
Reduce power: sleep mode, low TX, and short duty cycle. TEL0140TEL0142FAQSEO FAQAftersales FAQ
Hello, Can it be used with other transmitters and receivers? TEL0140TEL0142FAQSEO FAQAftersales FAQ
Can the receiver directly control the relay?ha TEL0140TEL0142FAQSEO FAQAftersales FAQ
Signal received without TX? Verify TX status & interference. TEL0140FAQSEO FAQAftersales FAQ
Minimize power: sleep mode, lower TX duty cycle, efficient components. TEL0140FAQSEO FAQAftersales FAQ
Help with Gravitiy Digital Self Powered Wireless Switch/Receiver - Pairing not working GravityTroubleshootingTEL0140
userHead Mark.McGookin 2025-10-14 13:57:11
The receiver is connected to the controller, why does the receiver receive signal when the transmitter does not transmit? TEL0140FAQAftersales FAQ
userHead Yx 2024-07-12 15:04:05
How to reduce power consumption when using a battery to connect the transmitter and sensor TEL0140FAQAftersales FAQ
  • 1 Arduino library for DFPlayer Mini
  • 2 Stepper motor selection
  • 3 DfPlayer recommended speaker impedance?
  • 4 New to DFPlayer (detect when audio clip has finished playing & loud pop upon power on/down)
  • 5 I want to use Python code to control Maqueen.
  • 6 Firebeetle ESP32 read battery voltage
  • 7 Firmware update (windows - failure
  • 8 How effective really are visual programming languages (like MIT's Scratch) for learning?
  • 9 Beetle ESP32 C3 USB connection issue
  • 10 ESP-32-C3 doesn't start with battery supply
logo
Information
  • About Us
  • Warranty
  • Terms & Conditions
  • Shipping
  • Payment
  • FAQ
Customer Service
  • DFRobot Distributors
  • Contact us
  • Site Map
My Account
  • Affiliates
  • Specials
  • Coupon
