Gravity: Analog Electrochemical Carbon Dioxide / CO2 Sensor (0-10000 ppm)
$48.90
SKU: SEN0159
  • $47.50 3+ items
  • $46.50 5+ items
  • $45.00 10+ items
Arduino-based CO2 sensor detects carbon dioxide levels, using MG-811 sensor. Features adjustable alarm, analog output, and onboard heating circuit for optimal performance.
Purchase this product and earn 489 reward points, which are tied to VIP membership program. Learn More >
"Greenhouse Effect" is melting the Earth ice core every minute and creating dangerous icebergs. By knowing the exact concentration of CO2(Carbon Dioxide), we can do something to reduce the CO2 and to protect our Earth. Here is the Arduino-based CO2 sensor designed by DFRobot lovely engineer.
This is the first CO2 sensor in the Arduino market.  The output voltage of the module falls as the concentration of the CO2 increases. The potentiometer onboard is designed to set the threshold of voltage. As long as the CO2 concentration is high enough (the voltage is lower than the threshold),  a digital signal (ON/OFF) will be released.
  • It has MG-811 sensor module which is highly sensitive to CO2 and less sensitive to alcohol and CO, low humidity & temperature dependency.
  • Onboard heating circuit brings the best temperature for the sensor to function. Internal power boosting to 6V for heating sensor best performance.
  • This sensor has an onboard conditioning circuit for amplifying output signal.
To ease the difficulty of using this CO2 sensor,  a Gravity Interface is adapted to allow plug&play.  The Arduino IO expansion shield is the best match for this CO2 sensor connecting to your Arduino microcontroller
Selection Guide
CO2 Sensor Selection Guide
Figure
SKU
SEN0159
SEN0220
SEN0219
SEN0536
Operation Voltage
3.7~5V
4.5~5.5V
4.5~5.5V
3.3V-5V
Output
Gravity: Analog (Analog2.7~4.1V) + 3P Header Digital Output(Alarm):0~VCC Level
Gravity: Analog (Analog Output 0.4~2V)
Gravity: UART (0~3.3V Level)
Gravity: I2C
Measurement Principle
Electrochemistry (Solid electrolyte battery principle)
NDIR (non-dispersive infrared)
photoacoustic NDIR
Measurement Range
0~10000 ppm
0~50000 ppm
400~5000 ppm
400~5000 ppm
Accuracy
±100ppm@400ppm
±(100ppm + 6% readings)
±(40 ppm + 5% MV)
Response Time
<20s
<90s
<30s
60s
Average Power
<1W
<430mW@5V
<430mW@5V
<30mW@5V
Operation Temperature
-20℃~50℃
0℃~50℃
0℃~50℃
-10℃~60℃
Operation Humidity
0~95% RH (No condensation)
Lifespan
>1 year
>5 year
>5 year
>10 year
Dimension (PCB)
32*42 mm
37*69 mm
21*27.1 mm
32*27*8mm
1. Large Range 2. Adjustable Alarm Threshold 3. Fast Response 4. Analog Output
1. High Accuracy 2. Long Lifespan 3. Auto Temperature Compensation 4. Water Vapor Interference Resistance 5. Ananglog Output
1. High Accuracy 2. Large Range 3. Long Lifespan 4. Auto Temperature Compensation 5. Water Vapor Interference Resistance 6.3.3V UART Output
1.CO2, temperature, and humidity, three in one 2. Small size of 32*27*8mm 3. Low power, average current<4mA
Add to Cart
  • Air Quality Control
  • Ferment Process Control
  • Room Temperature CO2 concentration Detection
  • Operating Voltage:5V
  • Interface: Gravity Analog
  • One digital output
  • High-quality connector
  • Immersion gold surface
  • Size:32x42mm (1.26x1.65")
  • Gravity: Analog Electrochemical Carbon Dioxide Sensor (0-10000 ppm) x1
How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2025 Selection Guide)
Blog How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2025 Selection Guide)
Mar 25, 2020
Jun 26, 2022
Aug 10, 2023
Dec 21, 2016
DFRobot's Gravity Sensors Enhance Data Collection in SAGA Underwater Habitat (UHAB)
Media DFRobot's Gravity Sensors Enhance Data Collection in SAGA Underwater Habitat (UHAB)
PR Newswire
Oct 24, 2023
