Gravity: Analog Electrochemical Carbon Dioxide / CO2 Sensor (0-10000 ppm)
$48.90
SKU: SEN0159
$47.503+ items
$46.505+ items
$45.0010+ items
Arduino-based CO2 sensor detects carbon dioxide levels, using MG-811 sensor. Features adjustable alarm, analog output, and onboard heating circuit for optimal performance.
Purchase this product and earn 489 reward points, which are tied to VIP membership program.
Learn More >
"Greenhouse Effect" is melting the Earth ice core every minute and creating dangerous icebergs. By knowing the exact concentration of CO2(Carbon Dioxide), we can do something to reduce the CO2 and to protect our Earth.
Here is the Arduino-based CO2 sensor designed by DFRobot lovely engineer.
This is the first CO2 sensor in the Arduino market. The output voltage of the module falls as the
concentration of the CO2 increases. The potentiometer onboard is designed to set the threshold of voltage. As long as the CO2 concentration is high enough (the voltage is lower than the threshold), a digital signal (ON/OFF)
will be released.
It has MG-811 sensor module which is highly sensitive to CO2 and less sensitive to alcohol and CO, low humidity & temperature dependency.
Onboard heating circuit brings the best temperature for the sensor
to function. Internal power boosting to 6V for heating sensor best performance.
This sensor has an onboard conditioning circuit for amplifying output signal.
To ease the difficulty of using this CO2 sensor, a GravityInterface is
adapted to allow plug&play. The Arduino IO expansion shield is the best match for this CO2 sensor connecting to
your Arduino microcontroller.
