Gravity: Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C)
$53.90
SKU: SEN0322
  • $52.00 3+ items
  • $51.00 5+ items
  • $50.00 10+ items
Compact electrochemical sensor measures ambient O2 concentration with high sensitivity and stability. Supports I2C output, 0-25%Vol range, compatible with 3.3V-5V microcontrollers.
Purchase this product and earn 539 reward points, which are tied to VIP membership program. Learn More >
This Oxygen / O2 Sensor is based on electrochemical principles and can measure ambient oxygen concentration accurately and conveniently. With high anti-interference ability, high stability, and high sensitivity, this Arduino-compatible oxygen sensor can be widely applied to portable devices, air quality monitoring systems, and environments such as industries, mines, warehouses, and other spaces where air circulation is limited.
Designed for measuring oxygen levels in ambient air (0–25%Vol), this sensor is ideal for applications such as environmental monitoring, safety detection in enclosed spaces, and oxygen concentration analysis.
This compact DFRobot oxygen sensor supports I2C output and can be calibrated in air for accurate measurement. It is compatible with many mainboards like Arduino Uno, ESP32, and Raspberry Pi. Its measurement range is 0~25%Vol, with a resolution of up to 0.15%Vol. It supports a wide input voltage range from 3.3V to 5.5V.
With a service life of over 2 years under normal conditions, along with a simple Gravity interface and practical sample code, users can quickly build their own oxygen concentration monitoring systems.
For optimal accuracy, periodic calibration is recommended depending on the usage environment.
Selection Guide
Oxygen / O2 Sensor Selection Guide
Figure
SKU
SEN0322
SEN0465
SEN0496
Detection Range
0~25%Vol
0~25%Vol
0~100%Vol
Calibration Method
Manual calibration
Factory calibration
Manual calibration
Output Signal
I2C
I2C/UART/Analog
I2C
Working Principle
Electrochemical
Electrochemical
Electrochemical
Stability
<2%/Month
<2%/Month
<10%/Year
Response Time
≤15S
≤15S
0.1%~20.9%<40S 20.9%~100%<5S
Operating Pressure Range
101kPa±10%
101kPa±10%
0.5 - 2.0 Bar
Temperature Compensation
Add to Cart
  • High sensitivity for accurate ambient O2 measurement
  • Standard I2C interface for simple data communication
  • Compatible with both 3.3V and 5V micro-controllers
  • Built-in polarity protection for enhanced hardware safety
  • Portable air quality monitoring devices
  • Environmental monitoring in industries and mines
  • Air circulation tracking in warehouses
  • Detection of Gas: oxygen / O2
  • Operating Voltage: 3.3 to 5.5V DC
  • Output Signal: I2C output
  • Measurement Range: 0~25%Vol
  • Maximum Measurement limit: 30%Vol
  • Resolution: 0.15%Vol
  • Sensitivity: (0.10±0.05) mA (in the air)
  • Stability: <2% (Every month)
  • Repeatability: <2%
  • Response Time: ≤15 seconds
  • Operating Temperature: -20~50℃
  • Operating humidity: 0~99%RH (no condensation)
  • Pressure Range: standard atmospheric pressure ±10%
  • Lifetime:> 2 years (in the air)
  • Dimension(L x W x H): 37 * 27 * 24.5 mm/1.46 * 1.06 * 0.97 inches
  • Weight:0.037kg
  • Gravity: Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C) x1
  • Gravity-4pin I2C Cable x1
  • M310 Nylon post x4
  • M35 Screws x8
    Jun 26, 2022
    Aug 10, 2023
    Niu.yx
    Feb 11, 2025
    Exploring the Components of Gases Human Breath In and Out With SCI and Air Sensors
    Projects Exploring the Components of Gases Human Breath In and Out With SCI and Air Sensors
    Qinchan.Wang
    Oct 16, 2023
    Explore how plants photosynthesize
    Projects Explore how plants photosynthesize
    Qinchan.Wang
    Oct 16, 2023
    Alén.Porto Feb 03, 2026
    Todo genial envio bien trato bien
    Juan.Navarro Jan 28, 2026
    It was a very simple purchase, the treatment was very friendly and the delivery was very fast, thank you
    KHALED. Oct 18, 2025
    high accuracy, and easy to use
