TF02-i ToF Single-Point Ranging Solid State LiDAR Sensor (40m, RS485, IP65)
$109.90
SKU: SEN0504
Industrial-grade LiDAR sensor with 40m range, adjustable 1KHz frame rate. Compatible with RS485, IP65 rated, suitable for UAVs, transportation, agriculture.
Purchase this product and earn 1099 reward points, which are tied to VIP membership program. Learn More >
TF02-i LiDAR is an industrial-grade medium-range ToF single-point ranging solid state sensor. Its maximum detection range can reach up to 40m and it has an adjustable frame rate with a maximum of 1KHz. This TF02-i solid state lidar is compatible with RS485 interface, it can be widely used in the Industrial fields of UAV height fixing, intelligent transportation, intelligent parking, intelligent agriculture, etc.
TF02-i ToF Single-Point Ranging Solid State LiDAR's FEATURES: small size compatible with RS485
High Performance
  • Maximum detection range is up to 40m.
  • Blind spot as low as 10cm.
  • Scanning frequency up to 1000Hz.
  • Working under 100K lux light without interference
  • More Suitable for Industrial Application
  • Compatible with RS485 interface.
  • Has a PC/ABS/PMMA enclosure with IP65 water and dust resistance.
  • With reverse protection to protect the internal circuit.
  • Supports a wide range of input voltages (7-30V) and reduce the damage caused by voltage fluctuations.
  • Easy to use
    The TF02-i TOF LiDAR can be used on the Arduino UNOR3 through the TTL to RS485 Shield, and it can also be used on the Raspberry Pi through the USB to RS485 module. Those two ways provided by DFRobot can make TF02-i LiDAR simpler to be used.
    TF02-i ToF Single-Point Ranging Sensor Connection
    How does TF02-i LIDAR work?
    TF02-i is a single point LiDAR, which is based on Pulse Time of Flight (PTOF).
    It adopts an incoherent energy receiving mode, and the detection is mainly based on Pulse counting. TF02-i emits a narrow pulse laser, which is collimated by the transmitting lens to form a collimated light, which enters the receiving system after being reflected by the measured target and is focused on the APD detector by the receiving lens. The time between the transmitted signal and the received signal is calculated through the circuit amplification and filtering, and the distance between TF02-i and the measured target can be calculated through the speed of light.
    Schematic diagram of TF02-i ToF Single-Point sensor
  • Wide range of input voltages (7-30V) with reverse protection
  • RS485 interface communication
  • Adjustable frame rate with a maximum of 1KHz
  • Medium range detection (0.1 to 40m)
  • IP65 protection for industrial application
  • Compatible with Arduino UNO R3 and Raspberry Pi
  • Detection of vehicle and pedestrian
  • Vehicle collision avoidance and safety warning systems
  • UAV assisted takeoff and landing
  • Altimeter
  • TF02-i ToF Single-Point Ranging Sensor Applications
    Product Performance
  • Operating Range:
          0.1-40m@90% reflectivity
          0.1-13.5m@10% reflectivity
          0.1-40m@90% reflectivity & 100Klux
          0.1-13.5m@10% reflectivity & 100Klux
  • Accuracy: ±5cm (0.1~5m), ±1% (5~40m)
  • Distance resolution: 1cm
  • Frame rate: 100Hz
  • Ambient light immunity: 100Klux
  • Operating temperature: -20~60℃
  • Repeatability: 1σ:<2cm(0.1~35m@90% reflectivity)
  • Enclosure rating: IP65
  • Optical Parameters
  • Light source: VCSEL
  • Central wavelength: 850nm
  • Photobiological safety: Class1 (EN60825)
  • FOV (Field of view): 3°
  • Electrical Parameters
  • Supply voltage: 7~30V
  • Average current: ≤70mA@12V
  • Power consumption: ≤0.85W@12V
  • peak current: 100mA
  • Others
  • Communication interface: RS-485
  • Dimensions: 69mmx41.5mmx31.5mm(L*W*H)
  • Enclosure material: PC/ABS/PMMA
  • Storage tempe rature: -30~80℃
  • Weight: 60g (with cable)
  • Cable length: 70cm
  • TF02-i LiDAR Laser Range Sensor (40m) x1
    Solid State LiDAR (Laser Radar) Selection Guide
    Blog Solid State LiDAR (Laser Radar) Selection Guide
    Mar 13, 2020
    Ryo. Jul 12, 2022
    Good product and affordable price. Shipping is also fast.
    Only 1 Left
