Gravity: Factory Calibrated Electrochemical SO2 Sensor (0-20ppm, I2C&UART)
$152.90
SKU: SEN0470
A sensor for detecting sulfur dioxide with analog, I2C, and UART outputs, featuring high stability and sensitivity, suitable for industrial and environmental use.
Purchase this product and earn 1529 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects sulfur dioxide concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of sulfur dioxide in the environment. Can be widely used in the detection of sulfur dioxide in industrial and environmental protection fields.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a sulfur dioxide concentration detector.
Gravity: SO2 Sensor (Calibrated) - I2C & UART
  • High stability
  • High sensitivity
  • Industrial sulfur dioxide detection
  • Detection Gas: Sulfur dioxide (SO2)
  • Detection range: 0~20ppml
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: SO2 Signal Conversion Board x1
  • SO2 sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    Aug 10, 2023
    Marco Antonio.Vera Garcia Dec 09, 2025
    son muy buenos sensores funcionaron a la perfeccion
    Nemanja.Janev Mar 31, 2025
    Realy easy conection and programing. I would recomend.
