This is a sensor that detects sulfur dioxide concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of sulfur dioxide in the environment. Can be widely used in the detection of sulfur dioxide in industrial and environmental protection fields.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a sulfur dioxide concentration detector.
Dec 09, 2025
son muy buenos sensores funcionaron a la perfeccion
Mar 31, 2025
Realy easy conection and programing. I would recomend.
