Gravity: Factory Calibrated Electrochemical Nitrogen Dioxide Sensor (0-20ppm, I2C/UART)
$152.90
SKU: SEN0471
  • $148.00 3+ items
  • $145.00 5+ items
  • $140.00 10+ items
Calibrated sensor detects nitrogen dioxide using analog, I2C, and UART outputs. Features high sensitivity, stability, and anti-interference, lasting over 2 years.
Purchase this product and earn 1529 reward points, which are tied to VIP membership program. Learn More >
This electrochemical sensor for detecting Nitrogen Dioxide (NO2) concentration. The detection range is 0 to 20ppm. The sensor module provides three output modes: I2C, UART (0-3V), and analog voltage. The probe is factory-calibrated and features an integrated temperature compensation algorithm and a threshold alarm function. The I2C address is user-modifiable (32 options). It operates on a 3.3V to 5.5V DC supply with a working current of less than 5mA. The probe has a service life of over two years in air. Compatible with Arduino, ESP32, and Raspberry Pi.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a nitrogen dioxide concentration detector.
Gravity: NO2 Sensor (Calibrated) - I2C & UART
  • High stability
  • High sensitivity
  • Industrial nitrogen dioxide detection
  • Underground nitrogen dioxide detection
  • Detection Gas: Nitrogen Dioxide(NO2)
  • Detection range: 0~20ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: NO2 Signal Conversion Board x1
  • NO2 sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    Aug 10, 2023
    AI-assisted Air Quality Monitor w/ IoT Surveillance
    Projects AI-assisted Air Quality Monitor w/ IoT Surveillance
    Kutluhan Aktar
    Apr 06, 2023
    Only 5 Left
