This electrochemical sensor for detecting Nitrogen Dioxide (NO2) concentration. The detection range is 0 to 20ppm. The sensor module provides three output modes: I2C, UART (0-3V), and analog voltage. The probe is factory-calibrated and features an integrated temperature compensation algorithm and a threshold alarm function. The I2C address is user-modifiable (32 options). It operates on a 3.3V to 5.5V DC supply with a working current of less than 5mA. The probe has a service life of over two years in air. Compatible with Arduino, ESP32, and Raspberry Pi.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The easy-to-use Gravity interface, coupled with our sample code, can quickly build a nitrogen dioxide concentration detector.
