Gravity: Factory Calibrated Electrochemical Ozone Sensor (0-10 ppm, I2C & UART)
$152.90
SKU: SEN0472
  • $148.00 3+ items
  • $145.00 5+ items
  • $140.00 10+ items
The sensor detects ozone levels with analog, I2C, and UART outputs, featuring high sensitivity and stability, suitable for industrial and environmental use.
Purchase this product and earn 1529 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects ozone concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of ozone in the environment. Can be widely used in industrial and environmental protection fields for ozone detection.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build an ozone concentration detector.
Gravity: O3 Sensor (Calibrated) - I2C & UART
  • High stability
  • High sensitivity
  • Industrial ozone detection
  • Detection Gas: ozone (O3)
  • Detection range: 0~10ppm
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: O3 Signal Conversion Board x1
  • O3 sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    Aug 10, 2023
    Ivan.Pavelic Nov 27, 2025
    Good sensors for industrial use.
    Only 12 Left
