Gravity: Electrochemical Oxygen / O2 Sensor (0-100%Vol, I2C)
$95.90
SKU: SEN0496
  • $93.00 3+ items
  • $91.00 5+ items
  • $88.00 10+ items
A full-scale oxygen sensor with a 0-100% measurement range, I2C output, strong anti-interference, and high sensitivity. Compatible with Arduino, ESP32, Raspberry Pi.
Purchase this product and earn 959 reward points, which are tied to VIP membership program. Learn More >
This full-scale oxygen / O2 sensor employs the original AO2 CiTiceL® oxygen sensor probe and features a measurement range of 0-100%Vol and I2C digital output, which can be adapted to application scenarios including oxygen / O2 generators, automobile exhaust, and air-fuel ratio detection.
The DFRobot oxygen / O2 sensor has a built-in calibration algorithm on the signal board that can quickly perform single-point or double-point calibration so as to accurately measure the oxygen / O2 concentration in the environment. Based on the principle of electrochemistry, the sensor probe comes with strong anti-interference ability, high stability and sensitivity, and up to two years of service life. It is compatible with mainstream controllers such as Arduino, ESP32, Raspberry Pi, etc. Besides, the sensor is designed with an easy-to-use Gravity interface, and with our sample codes, you can quickly build an oxygen / O2 detector.
Caution: Exposure to high concentrations of solvent vapors is avoided, both during storage, fitting into instruments, and operation.
Gravity: Electrochemical Oxygen Sensor (0-100%Vol) - I2C
Selection Guide
Oxygen / O2 Sensor Selection Guide
Figure
SKU
SEN0322
SEN0465
SEN0496
Detection Range
0~25%Vol
0~25%Vol
0~100%Vol
Calibration Method
Manual calibration
Factory calibration
Manual calibration
Output Signal
I2C
I2C/UART/Analog
I2C
Working Principle
Electrochemical
Electrochemical
Electrochemical
Stability
<2%/Month
<2%/Month
<10%/Year
Response Time
≤15S
≤15S
0.1%~20.9%<40S 20.9%~100%<5S
Operating Pressure Range
101kPa±10%
101kPa±10%
0.5 - 2.0 Bar
Temperature Compensation
Add to Cart
  • High stability and sensitivity
  • Oxygen / O2 generators
  • Automobile exhaust
  • Air-fuel ratio detection
  • Physical Quantity Detected: Oxygen / O2 concentration
  • Measuring Range: 0~100%
  • Output Signal: I2C
  • Working Pressure Range: 0.5~2.0Bar
  • Operating Temperature Range: -20°C ~ +50°C
  • Operating Humidity Range: 0-99% RH (non-condensing)
  • Response Time: <5S
  • Lifespan: >2 years (in air)
  • Size: 32mm*27mm/1.26*1.06 inch
  • Mounting Hole Size: inner diameter 3.1mm(0.12 inch)/outer diameter 6mm(0.24 inch)
  • Compatible with Arduino, ESP32, Raspberry Pi
  • Gravity: AO2 Oxygen / O2 Sensor Signal Adapter Board x1
  • AO2 Oxygen / O2 Sensor Probe x1
  • Gravity-4Pin Cable x1
  • Molex 2510 - PH2.0 cable (20CM)  x1
    Jun 26, 2022
    Aug 10, 2023
    DFRobot's Gravity Sensors Enhance Data Collection in SAGA Underwater Habitat (UHAB)
    Media DFRobot's Gravity Sensors Enhance Data Collection in SAGA Underwater Habitat (UHAB)
    PR Newswire
    Oct 24, 2023
    DFRobot Open-Source Hardware Gravity Series Unleashes the Creativity for More Than 1 Million Developers Now
    Media DFRobot Open-Source Hardware Gravity Series Unleashes the Creativity for More Than 1 Million Developers Now
    PR Newswire
    May 19, 2021
    Out Of Stock
