Hi,1) efficiency chart is showing Vo = 3.3v while the product specs, talk about 5v output?2) is there a Vo over load chart available for different Vi values? 3) Is the minimum Vi r... FAQDFR0569SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:14 295 Views
Are there any documentation on the CR123A Li-ion Battery Holder for micro: Maqueen unit? I.E. Schematic, Board LayoutI would like to check battery charge and make the robot Maqueen... FAQFIT0611SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:14 293 Views
Hi the wiki for this product is showing a blank page. Do you have any sample code for this driver? FAQDRI0042SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:14 323 Views
Hi all! anyone know if is it possible to change the sample rate?Thanks in advance FAQDFR0420SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:14 338 Views
is this an arduino board that is ready to code, or would I have to make the circuit in the schematic to make the module work as one? FAQTEL0110SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:14 252 Views
will this work for a raspberry pi?p.s.Also I dream of the day when DFROBOT makes a larger devastator tank tracks with a higher payload capacity. FAQDFR0223SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 290 Views
What’s the wiresize (AWG)? FAQFIT0030SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 265 Views
This include a USB Cable for the latte panda? FAQFIT0318SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 268 Views
do you have a sample code in C, not for Arduino? it is missing in this web page. https://www.dfrobot.com/wik... FAQTEL0080SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 309 Views
Hi, When are you going to re-stock up again and does it support common anode RGB LED Matrix ? FAQDFR0202SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 289 Views
Hi folks,I have a "Rover 5 Tank Chassis (4 motors with 4 Encoders) / SKU:ROB0055-4M4E" and a "Romeo for Intel® Edison Controller (With Intel® Edison) SKU:DFR0350" to drive it...Two... FAQROB0055-ESEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 295 Views
What is the differences between 3DP0003-CB-EU and 3DP0003-CB-EU(S)?If you can answer to me immediately, I will be thankful. FAQTDP0003-CB-EUSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 404 Views
We purchased this via Amazon.c..uk. This is a great product, bought it for my 10 year old for Christmas. However, we are having difficulty getting the Mini Servo to work. It see... FAQTOY0086SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 1393 Views
Does it support the Arduino Giga R1 WiFi board? FAQSEN0236SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 348 Views
Is it okay to power this using 3.3V? FAQSEN0128SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:13 308 Views
Is there a fritzing add on/ library available? FAQDFR0484SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:12 263 Views
This looks like it could be a good speaker to use with the mini MP3 player I recently purchased. FAQFIT0502SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:12 298 Views
Please post the source for the pogo pins for people who would like to build a custom adapter. FAQDFR0359SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:12 249 Views
I will use that servo to making a feed back glove whick like the VR glove in movie "first player ready" FAQSER0044SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:12 265 Views
Do you have Wheel Coupling Kit to suit 8 mm Motor Shaft for this Wheel? FAQFIT0252SEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:12 Trending
