BLOG
REVIEWS
Reviews for DFRobot latest products, such as LattePanda Sigma reviews, LattePanda 3 Delta reviews, LattePanda Alpha reviews, micro:Maqueen Plus reviews, Raspberry Pi reviews, Arduino sensor and kits reviews.
  • Gravity GP8630N 16-bit DAC Test Report | High-Accuracy I2C & PWM Performance Analysis
    Gravity: GP8630N DAC Module Accuracy Test Report
    This test report presents a comprehensive laboratory evaluation of the Gravity GP8630N 16-bit DAC module, focusing on its voltage and current output accuracy under both I2C and PWM interfaces.
    REVIEWS
    Mar 04 2026
  • FireBeetle 2 ESP32-C5 Review: Dual-Band Wi-Fi 6 & Solar Charging for IoT - DFRobot
    FireBeetle 2 ESP32-C5 IoT Development Board Review: Dual-Band Wi-Fi 6 and Solar Charging
    Explore the new FireBeetle 2 ESP32-C5, a powerful IoT development board featuring dual-band 2.4/5GHz Wi-Fi 6, multi-protocol support (BLE, Zigbee, Thread), and integrated solar charging. See how it outperforms the ESP32-C6 for advanced, low-power projects.
    REVIEWS ESP32
    Jul 15 2025
  • Tutorial of Run Qwen2.5 Small Language Model on Raspberry Pi 5 using Ollama
    Run Qwen2.5 on Raspberry Pi 5 using Ollama
    This article will explore how to install and run Qwen2.5 on a Raspberry Pi 5 using the Ollama runtime framework.
    REVIEWS Raspberry Pi
    Dec 11 2024
  • Running Gemma2 AI Model on a Raspberry Pi 5 using the Ollama
    Run Gemma2 on Raspberry Pi 5 using Ollama
    In this article, we will delve into the process of installing and running the SLM(small language model) Gemma2 on the Single Board Computer (SBC) Raspberry Pi 5 using the Ollama runtime framework.
    Dec 11 2024
  • Tutorial and Test of Run phi3.5 Small Language Model on Raspberry Pi 5 Single Board Computer using Ollama
    Run phi3.5 on Raspberry Pi 5 using Ollama
    In this write-up, we delve into the process of installing and executing phi3.5-3.8b on a Raspberry Pi 5, leveraging the Ollama runtime framework.
    Dec 09 2024
  • Global Shutter Camera Module Test Report & Performance Evaluation Review - Raspberry Pi Compatible
    Global Shutter Camera Module Test Report and Performance Evaluation
    The 100W global shutter Raspberry Pi camera module test report covers key tests such as image quality, resolution, distortion, grayscale, and field of view, Ideal for dynamic monitoring applications, gesture recognition, head tracking, and autonomous driving.
    REVIEWS
    Dec 05 2024
  • Performance Analysis of SLM (mathstral, phi 3, llama 3.1, gemma2 2b, and Qwen) on Raspberry Pi 5 SBC
    Run Small Language Models (Mathstral, phi 3, Llama 3.1, Gemma2 2b, Qwen) on Raspberry Pi 5
    Explore the performance of Small Language Models (SLMs) on the Raspberry Pi 5 SBC, including models like mathstral, phi 3, llama 3.1, gemma2 2b, and Qwen.
    REVIEWS
    Oct 24 2024
  • YOLOv10 and YOLOv8 Object Detection Model Comparison and Selection Guide
    Review of YOLOv10 vs YOLOv8: Model Size, Performance Metrics, benchmark on x86 SBC and PC
    This blog will provide an in-depth comparison of YOLOv10 and YOLOv8, analyzing their differences in model size, performance metrics, and hardware requirements.
    REVIEWS
    Sep 22 2024
  • Color and Light Testing with Gravity: Factory Calibrated Correlated Color Temperature (CCT) & ALS Meter for Professional Photography
    Precision Test Report on Color Temperature and Illuminance of the Gravity CCT & ALS Meter
    Discover how the Gravity CCT & ALS Meter accurately measures color temperature and illuminance under various lighting conditions.
    REVIEWS
    Aug 28 2024
  • Jetson copilot review: Exploring llama3 and RAG applications based on Jetson Orin 64GB
    The newly released Jetson Copilot has attracted a lot of attention. Through this review based on the Jetson Orin 64GB platform, we will have a comprehensive understanding of the functions and performance of Jetson Copilot and its potential in practical applications.
    REVIEWS AI
    Jul 12 2024
  • Fall Detection and Sleep Tracker Comprehensive Testing of the DFRobot C1001 mmWave Human Detection Sensor
    Functional Test Report of DFRobot C1001 mmWave Sensor (Fall Detection and Sleep Quality)
    Discover how the DFRobot C1001 mmWave Human Detection Sensor excels in fall detection, sleep monitoring, and more. Read our in-depth tests and results.
    REVIEWS Arduino
    Jul 12 2024
  • Deploy and run LLM on Raspberry Pi 5 vs Raspberry Pi 4B (LLaMA, LLaMA2, Phi-2, Mixtral-MOE, mamba-gpt)
    Deploy and run LLM on Raspberry Pi 5 vs Raspberry Pi 4B (LLaMA, LLaMA2, Phi-2, Mixtral-MOE, etc)
    We will introduce how to deploy and run the recently popular LLM (large language models), including LLaMA, LLaMA2, Phi-2, Mixtral-MOE, and mamba-gpt, on the Raspberry Pi 5 8GB.
    REVIEWS AI
    Jan 02 2024
  • NVIDIA Jetson AGX Orin Large Language Model LLaMA2-7b and LLaMA2-13b Performance Test Report
    Explore the capabilities of NVIDIA Jetson AGX Orin in handling large language models (LLaMA2-7b and LLaMA2-13b ). Discover its impressive computing power and how it stands unparalleled in the market.
    REVIEWS AI
    Dec 20 2023
  • Unveiling the Arduino UNO R4: A Comprehensive Review & Compatibility Guide
    Dive into the world of Arduino UNO R4 and its upgraded features. From wireless connectivity and LED matrix to VRTC and OFF pins, discover its compatibility with digital, analog, I2C, UART devices, and expansion boards.
    REVIEWS Arduino
    Oct 10 2023
  • Review and Guide of the DFRobot Fermion MEMS Gas Sensor Series for Accurate Gas Detection
    The DFRobot Fermion MEMS Gas Sensor Series uses MEMS technology to detect a variety of gases with fast response and recovery times. Suitable for environmental monitoring, indoor safety, and much more.
    REVIEWS Arduino
    Jul 27 2023
  • LakiBeam 1 - 270 Degree Industrial-grade Single-line 2D ToF LiDAR Review
    LakiBeam 1 ToF LiDAR Review
    In this review, we evaluate the LiDAR's performance and functional requirements in three sections: LiDAR parameters, LiDAR performance, and mapping.
    REVIEWS
    May 30 2023
  • Run Gaming Emulators on LattePanda SBC
    Expect to see updates as we test emulators for handheld gaming systems on the LattePanda SBC’s and find other emulators to test and evaluate on our powerful mini computers!
    REVIEWS LattePandaDFRobot
    Oct 21 2020
  • micro:Maqueen Plus + Mechanic-Loader
    micro:Maqueen Plus + Mechanic-Loader Introduction (Japanese)
    micro:Maqueen Plusのオプションとして用意されているMechanic-Loader(メカニックローダー)の取り付け手順を紹介します。
    REVIEWS RoboticsDFRobotJapanese
    Jun 02 2020
    micro:Maqueen Plus Introduction (Janpanese)
    独立した二つの駆動輪を持つSTEM教育用のグラフィカルプログラミングロボット「micro:Maqueen Plus」を紹介します。より高度な学びへつながる高い拡張性を備えています。
    Jun 02 2020
  • LattePanda Alpha - The Ultimate Mini PC for Gaming and More
    САМЫЙ МОЩНЫЙ МИНИ ПК НА ПЛАНЕТЕ! ТЕСТ В ИГРАХ
    Learn about the LattePanda Alpha 864s, a powerful mini PC with Windows 10 Pro, an Intel processor, and UHD 615 graphics. Ideal for gaming, robotics, and creative projects.
    REVIEWS LattePanda
    Apr 27 2020
  • How to Install Geekworm NVIDIA Jetson Nano Metal Case with Power & Reset Control Switch
    Cool!!! JETSON Nano Metal Case - DFRobot
    Learn how to install the Geekworm NVIDIA Jetson Nano Metal Case with Power & Reset Control Switch. Perfect for robotics & DIY projects. Step-by-step tutorial included!
    REVIEWS UnboxingJetson Nano
    Feb 21 2020
  • DFRobot Maker Friend Story——ProjectSbc
    We invited our maker friend ProjectSbc to come and share the making stories
    REVIEWS LattePanda
    Dec 31 2019
  • DFRobot Maker Friend Story——倉本大資  Daisuke Kuramoto
    We invited our friend Daisuke Kuramoto to come and share his making story.
    REVIEWS
    Dec 31 2019
  • Capacitive v/s Resistive Soil Moisture Sensor
    Capacitive and Resistive Soil Moisture Sensor, Which one to use? Confused! Look our guide and get your doubts clear.
    REVIEWS ArduinoGravity
    Jan 21 2019
    • 1
    • 2
    • 3
    Page 1 of 3
