Long press reduces TX range? Check energy storage leakage or signal damping. TEL0146FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 569 Views
Check compatibility, voltage, and signal protocols when pairing with other receivers. TEL0146FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 912 Views
FireBeetle+GDI screen not working? Check connections, power, and code config. DFR0934FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 583 Views
Hi, What can I do if a file cannot be deleted? TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 1097 Views
And when will the module enter USB flash drive mode? When to enter data storing mode? TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 580 Views
why the SD indicator is not lit when data is rapidly written to the module. TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 670 Views
and the CONFIG.TXT file isn't automatically generated when the module is powered on. TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 614 Views
Minimize power: sleep mode, lower TX duty cycle, efficient components. TEL0140FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 628 Views
Only 2 mounting blocks for 3 modules (anemometer, vane, rain)? Check manual. SEN0186FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 582 Views
Hi, Receiver connected to controller, no TX signal but receives signal. TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 622 Views
Reduce power: sleep mode, low TX, and short duty cycle. TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 722 Views
Hello, Can it be used with other transmitters and receivers? TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 537 Views
Can the receiver directly control the relay?ha TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 633 Views
No output/wrong data? Check code, wiring, power & baud rate. SEN0497FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 1277 Views
Do the ORP probe need to be calibrated? How often? SEN0464FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 568 Views
How long can ORP electrodes be used? SEN0464FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 609 Views
How to clean the ORP probe? SEN0464FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 589 Views
Signal received without TX? Verify TX status & interference. TEL0140FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 592 Views
What if getting DHCP fails? DFR0125FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 759 Views
The browser webpage could not be loaded, what should I do? DFR0125FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 Trending
- 9 DFR0548 IIC Label??
