DS18B20 current consumption
Unread postPosted:Wed Apr 14, 2021 2:36 pm
by zachary_fields
Both the forum and the product page list that it requires 3-5V to operate, but they do NOT specify how much current is required.
I'm trying to build a circuit around this device, but I need to know it's power requirements before I can proceed.
What is the amount of current in mA required to power this device?
Re: DS18B20 current consumption
Unread postPosted:Fri Apr 16, 2021 6:25 am
by 347945801
If you provide a stable DC power supply, it will not produce more than the rated current, so please rest assured to use.
Unread postPosted:Wed Apr 21, 2021 12:33 pm
by zachary_fields
What is the "rated current"? That is my question.
I cannot find the answer anywhere.
Unread postPosted:Tue Apr 27, 2021 2:13 am
by 347945801
These boards generally do not determine the size of the current, generally not too large, and the boards that require a larger current will be specially explained.
