Gravity: Factory Calibrated Electrochemical Oxygen / O2 Sensor (0-25%Vol, I2C & UART)
$84.90
SKU: SEN0465
  • $83.00 3+ items
  • $81.00 5+ items
  • $78.00 10+ items
The sensor detects O2 concentration with analog, I2C, and UART outputs. It is factory-calibrated, highly sensitive, stable, and suitable for diverse applications.
Purchase this product and earn 659 reward points, which are tied to VIP membership program. Learn More >
This is a sensor that detects oxygen / O2 concentration and supports three output modes: analog, I2C, and UART. The probe has been calibrated at the factory, which can quickly and accurately measure the concentration of oxygen / O2 in the environment. Can be widely applied to fields like portable devices, air quality monitoring devices, industries, mines, warehouses, and other spaces where the air is not easy to circulate.
The probe adopts the electrochemical principle, has the characteristics of strong anti-interference ability, high stability, high sensitivity, etc., and the service life is as long as two years. The sensor has 32 modifiable I2C addresses, an integrated temperature compensation algorithm, and a threshold alarm function, It has good compatibility with mainstream main control devices such as Arduino, ESP32, and Raspberry Pi. The easy-to-use Gravity interface, coupled with our sample code, can quickly build an oxygen / O2 concentration detector.
Gravity: O2 Sensor (Calibrated) - I2C&UART
How An Electrochemical Oxygen / O2 Sensor Works - Gravity: O2 Sensor (Calibrated) - I2C & UART
Selection Guide
Oxygen / O2 Sensor Selection Guide
Figure
SKU
SEN0322
SEN0465
SEN0496
Detection Range
0~25%Vol
0~25%Vol
0~100%Vol
Calibration Method
Manual calibration
Factory calibration
Manual calibration
Output Signal
I2C
I2C/UART/Analog
I2C
Working Principle
Electrochemical
Electrochemical
Electrochemical
Stability
<2%/Month
<2%/Month
<10%/Year
Response Time
≤15S
≤15S
0.1%~20.9%<40S 20.9%~100%<5S
Operating Pressure Range
101kPa±10%
101kPa±10%
0.5 - 2.0 Bar
Temperature Compensation
Add to Cart
  • High stability
  • High sensitivity
  • Air quality monitoring device
  • Mining air detection
  • Environmental protection
  • Smart Farming
  • Detection Gas: Oxygen (O2)
  • Detection range: 0~25%Vol
  • Working Current: <5mA
  • Adapter Plate Size: 37*32mm
  • Gravity: Oxygen / O2 Signal Conversion Board x1
  • Oxygen / O2 sensor probe x1
  • Gravity - 4pin Cable x1
    Jun 26, 2022
    2022 Top 10 New Products
    Blog 2022 Top 10 New Products
    Jan 10, 2023
    Aug 10, 2023
    Marco Antonio.Vera Garcia Dec 09, 2025
    son muy buenos sensores funcionaron a la perfeccion
