PROJECTS micro:bit
micro:bit Project: micro:bit Selfie Remote
DFRobot Jan 02 2018 261151
What is micro:bit?
The Micro Bit is an ARM-based embedded system designed by the BBC for use in computer education in the UK.
The board is 4 cm × 5 cm and has an ARM Cortex-M0 processor, accelerometer and magnetometer sensors, Bluetooth and USB connectivity, a display consisting of 25 LEDs, two programmable buttons, and can be powered by either USB or an external battery pack.
The device inputs and outputs are through five ring connectors that are part of the 23-pin edge connector.
Use the micro:bit as a wireless Bluetooth remote for a smartphone's camera.
Step 1: Things You Need for This Project
Hardware components:
BBC micro:bit Go × 1
Android Smartphone × 1
Software apps and online services:
micro:bit Android App
Microsoft MakeCode
Step 2: Pairing
Please follow the steps for pairing:
Open the installed micro:bit app and switch ON the bluetooth.
Tap on 'Connect' and tap on pair.
Connect the micro:bit with the battery.
Hold "A" and "B" button and click on "RESET" button for 1 second.
micro:bit will show PAIRING MODE on the front side.
Then, proceed for next step and enter the pattern shown on micro:bit in phone.
Enter the code in phone which is shown on the phone.
Step 3: Blockcoding
Go to Make Code by Microsoft and make the shown code using the blocks. Then, click on 'Download' and move the .hex file to the micro:bit drive shown in file explorer
Step 4: How It Works
Place your phone wherever you want it to take the photo from.
Get in position with your props - make sure you’re still in the camera’s view!
Press the A button to take your photo ­- voila, remote controlled selfie!
You can also record a video for an even more awesome message.
Before you start coding, make sure you’ve installed and signed into the micro:bit app. You should also connect your phone or tablet to your micro:bit.
Once you’ve completed these steps, you should see your connected micro:bit in the ‘Connections’ section of the app.
Step 5: Code
download microbit-Untitled.hex
Related Blog Post:
Microbit Tutorials
Micro:bit board: an introduction
5 Easy Steps for you to Quick Start with BBC Microbit
Micro:bit JavaScript Blocks Editor: Hello World
Micro:bit JavaScript Blocks Editor: Turning LEDs on and off
Micro:bit JavaScript Blocks Editor: Detecting button click events
Micro:bit JavaScript Blocks Editor: String interpolation
Micro:bit: MicroPython support
Microbit Projects
Mobile Doorbell System with BOSON and Micro:bit
How To Make A Micro:bit Heart Rate Monitor
Microbit Project micro:bit Laser Target
Micro:bit Surprise box
Microbit Project: Micro:bit Selfie Remote
Micro:bit Project: Light(Mood Lamp)
Micro:bit Project: Yes/No Bear
Smart Fan Control System with Micro:bit
LED writing board (micro:bit compatible)
micro:bit car with DFRobot gamepad
OBLOQ-IoT Module +Micro:bit IoT Flower Watering
