OBD kit keeps reconnecting Telematics General TEL0100
Need help on Project viability Telematics General
How To Read analog input voltage from A0 (First pin of the analog header) Telematics General
Problems with new Freematics OBD Adapter V2 Telematics General
Older UART with Datalogger Kit #2 Connector Issue Telematics General
Will not compile after fresh install of MultiLCD.h Telematics General
Flip 180 image TFT screen Telematics General
UTFT Library and Logger Kit II Telematics General
Super slow (20 seconds) data from UART OBD II connector. Telematics General
Running a ODB kit #3 with megalogger Issues Telematics General
OBD-II adapter power supply for GPRS shield Telematics General
Problem with Nissan OBD Telematics General
New Datalogger and older UART Ver1.2 Telematics General
How to get the default firmware back on the I2C Adapter Telematics General
About Forum
DFRobot forum
New to Forum?
- 1 DFR0550 - 5'' 800x480 TFT Raspberry Pi DSI Touchscreen
- 4 Huskylens FAQ【SEN0305】
- 5 DFPlayer Pro FAQ【DFR0768】
- 6 IoT Router Carrier Board Mini FAQ【DFR0767】
- 7 Analog TDS Sensor FAQ【SEN0244】
- 8 Analog Water Pressure Sensor FAQ【SEN0257】
- 9 Throw-in Type Liquid Level Transmitter FAQ【KIT0139】
- 10 A02YYUW Waterproof Ultrasonic Sensor FAQ【SEN0311】
