Reduce power: sleep mode, low TX, and short duty cycle. TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 705 Views
Hello, Can it be used with other transmitters and receivers? TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 502 Views
Motor won't spin despite power light? Check code, wiring, and driver circuit. ROB0148-EN-LFAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 514 Views
Can the receiver directly control the relay?ha TEL0140TEL0142FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 681 Views
Do Geiger tubes have a life span? How long does it need to be replaced? SEN0463FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 536 Views
Long press reduces TX range? Check energy storage leakage or signal damping. TEL0146FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 609 Views
No output/wrong data? Check code, wiring, power & baud rate. SEN0497FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 605 Views
Only 2 mounting blocks for 3 modules (anemometer, vane, rain)? Check manual. SEN0186FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 740 Views
The browser webpage could not be loaded, what should I do? DFR0125FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 573 Views
What if getting DHCP fails? DFR0125FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 1256 Views
Do the ORP probe need to be calibrated? How often? SEN0464FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 587 Views
How to clean the ORP probe? SEN0464FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 543 Views
How long can ORP electrodes be used? SEN0464FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 572 Views
Signal received without TX? Verify TX status & interference. TEL0140FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 594 Views
Minimize power: sleep mode, lower TX duty cycle, efficient components. TEL0140FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 552 Views
Check compatibility, voltage, and signal protocols when pairing with other receivers. TEL0146FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 649 Views
and the CONFIG.TXT file isn't automatically generated when the module is powered on. TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 562 Views
why the SD indicator is not lit when data is rapidly written to the module. TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 888 Views
FireBeetle+GDI screen not working? Check connections, power, and code config. DFR0934FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 1077 Views
And when will the module enter USB flash drive mode? When to enter data storing mode? TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 Trending
- 3 Cannot found Download for BlunoFWDownloader
- 4 DfPlayer recommended speaker impedance?
- 6 I want to use Python code to control Maqueen.
- 7 Firebeetle ESP32 read battery voltage
- 8 Firmware update (windows - failure
- 9 How effective really are visual programming languages (like MIT's Scratch) for learning?
- 10 Beetle ESP32 C3 USB connection issue
