Can Bluno M3's 5V ICSP header connect to 5V SPI devices like Pixy? DFR0329FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 548 Views
I can't install the driver on Windows 8/10 DFR0329FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 531 Views
Can I use Bluno M3 on a MAC or Linux platform? DFR0329FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 533 Views
Some general Arduino Problems/ FAQ/ Tips, very good to know. DFR0329FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 638 Views
Bluno Beetle (Central) won't auto-connect to Bluefruit BLE (Peripheral) DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 598 Views
BlunoBasicDemo disconnects in background - how to maintain BLE link? DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 682 Views
Default password is often '0000' or '1234' - ensure Bluno's BLE is discoverable. DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 581 Views
Check COM port permissions, BLE pairing, and ensure bootloader mode is active. DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 626 Views
Possible with CC2540 programmer & Bluno firmware hex file. DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 538 Views
How to use the Ibeacon function? DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 511 Views
Bluno to phone data issue: iOS devices receive unreadable data DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 587 Views
I cannot upload any new sketch to Bluno on my PC. DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 527 Views
Bluno firmware upload fails with 'serial timeout' error DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 623 Views
Setup BLE master to auto-connect to slave device DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 576 Views
Is it possible to connect several peripherals BLE to a single CENTRAL one? DFR0267FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:26 912 Views
FireBeetle+GDI screen not working? Check connections, power, and code config. DFR0934FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 583 Views
Hi, What can I do if a file cannot be deleted? TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 529 Views
Why does the button module sometimes not work after downloading the program? DFR0991FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 1097 Views
And when will the module enter USB flash drive mode? When to enter data storing mode? TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 580 Views
why the SD indicator is not lit when data is rapidly written to the module. TEL0148TEL0147FAQSEO FAQAftersales FAQ
JaneYu 2026-02-14 08:57:25 Trending
- 9 DFR0548 IIC Label??
