[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 580: sizeof(): Parameter must be an array or an object that implements Countable
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/session.php on line 636: sizeof(): Parameter must be an array or an object that implements Countable
Bluno Beetle - Blink on-board LED? - Arduino Robot IOT Community Forum - DFRobot
By diy
#12541
I'm stumped. I'm looking to do some debugging using the on-board LED while connected to Bluetooth. However, I am not sure how and have not found docs indicating which pin the LED is connected to.. I've tried digitalWrite to all digital pins (0 and up, including the standard Uno pin #13). Even tried all analog pins. I can see the RX/TX and even pwr LEDs blink when uploading sketches, so I know the LEDs are good. What am I missing? Should I not be able to blink either the RX/TX if writing to D0/1?
