Easy IoT is a simplest IoT Solution presented by DFRobot
#28511
Hi my friends
I will be appreciated if any one could help me for making the following code heart rate which include timer 2
https://www.dfrobot.com/wiki/index.php/ ... mple_Code2
To be compatible with NOD MCU because every time run , ,that message shown
#error MyTimer2 library only works on AVR architecture
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
So, I ask if there is another code for a solution or heart rate is work normal on NODMCU or Timer 2 work on NODMCU .
Thanks alot
